https://www.facebook.com/marketplace...ibextid=6ojiHh
These are brand new in the box COMPLETE SUSPENSION REBUILD KIT including BILSTEIN TC Performance shocks
Steering Tie Rod end LEFT Inner + Outer
Steering Tie Rod end RIGHT Inner + Outer
KYB Front Bellows Dust boots w. Bump stops
KYB Rear Bellows Dust boots w. Bump Stops
Front Upper Strut Mounts
Front LEFT Lower Control Arm
Front RIGHT Lower Control Arm
Front LEFT Upper Support Control Arm
Front RIGHT Upper Support Control Arm
Stabilizer Bar Link Kit FRONT
Stabilizer Bar Link Kit Rear
REAR Trailing Arm Bushing Set
REAR Pitman Trailing Arm Support Bushings DogBones Left+Right
BILSTEIN TC Front Shock Cartridge
BILSTEIN TC Rear Shocks
NO MORE CLUNKS, SQUEAKS, OR WANDERING of the front and rear end.
Don't replace another component every week.
Make your car safer and as good as new again.
Address all the problems in one shot.
To fit
1983 - 1989 E24 CHASSIS BMW 633csi 635csi M6
Feel the difference with a smoother and way better handling ride. The best parts you will ever replace on your car. Works with stock and Lowering springs. . No APO, FPO or PO box addresses please.
NOTE. The Fronts of this item is a shock Cartridge insert, Therefore For the front struts you have to Re-Use the front serviceable strut housing that has the spring seat on it, just open the top large gland nut slide old shock insert out, slide this new front shock insert in and re cap with new Gland nut provided in the box.
