From reading online, looks like its either the amp or the headunit that fail on these cars causing no sound output through the speakers. How can i definitively diagnose if it is the headunit or the amp before buying replacement parts? Thanks!
-Jon
-M3J0N
I'm currently having the same issue! Will be testing another amp shortly to see if that's the issue or not!
Current Cars: 2001 750iL, 2001 540iT
Previously Owned: 2003 530i, 1998 M3, 2001 740i, 2004 M3, 2000 M5
Ben, Glad to hear that amp took care of it. Exactly the same situation with my wagon. Mine showed a little corrosion on one of the plugs, from a water leak? I swapped in a clean amp and everything works fine now. Something tells me the tourings are prone to a minor water leak in that rear corner.
Jon, Check the plug connections on your amp for minor corrosion. What year and model is your touring? Is your amp silver w/diagonal alloy heatsink, or black w/vertical black heatsink? I may have another amp to try.
-Donny
