eBMWParts
Results 1 to 7 of 7
Thread: Suspension
    Dec 2022
    Conroe, Texas
    2016 BMW 329i
    Suspension
    Just purchased a 2016 328i F30 with 55k miles. Car rides as thou it needs coils and bushings. Ideas and cost?
    Jun 2012
    San Antonio, TX
    1995 BMW M3 Coupe
    Suspension
    I have a 2014 F30 328i with 108k miles on it, and it’s been a TX car for its whole life. The bushings are still fine. What makes you think the bushings are worn out on your car that is half the age and has half the miles that mine does?
    The dampers (front struts and rear shocks) on mine have seen better days, so the car bounces and floats more than it used to. So I’m going to replace them in the coming months, along with new bump stops, and possibly upper mounts if they seem to be worn. I am considering the Koni Special Active struts and shocks, which use Koni’s Frequency Selective Damping (FSD) technology.
    https://www.koni-na.com/en-US/NorthA...-Active-(Red)/
    Dec 2022
    NH
    M3
    Quote Originally Posted by MasterGuns View Post
    Yes, I have an idea. Replace bushings and other broken parts of your suspension.
    Jul 2021
    Renton, WA
    "13 335 & "14 328 sedans
    Old string but hoping someone will assist. I just got a quote to replace all 4 of the dampers on my 2013 335i xDrive sedan from a BMW performance tuner that is conveniently located near my house. I wanted to try them out But their estimate allowed for 10 hours to replace the 4 dampers at a rate of $190/hr. I don't have a huge issue with the hourly (should I?) but 10 hours? How long should it typically take?
    Jun 2012
    San Antonio, TX
    1995 BMW M3 Coupe
    Quote Originally Posted by ronbo335 View Post
    I have never worked on an xDrive model, so I don’t know if it is more complicated to replace the dampers…but I doubt that it is.
    Ten hours of labor sounds excessive for a professional shop. An experienced backyard mechanic could do the replacement faster than that. I am preparing to replace the struts and shocks on my F30 328i (non xDrive), and will be re-using the springs, so I will need to disassemble the front struts to swap the springs to the new struts. The rear springs are separate from the rear shocks, and the rear upper mounts disconnect from the fender wells, so there is no need to remove the rear deck or trunk trim to access the upper mounts.
    Jul 2021
    Renton, WA
    Thanks for the reply, confirmed my concern. I got a quote from my usual shop a year or so ago and their labor was about half of what this new shop quoted but hard to tell how many hours they bid. What are you going to replace your struts and shocks with? I've been pretty set on Bilstein B6 as I feel currently handling is just too soft, especially during hard transitions, emergency lane change type movements.
    Jun 2012
    San Antonio, TX
    1995 BMW M3 Coupe
    Suspension
    I bought Koni Special Active shocks and struts, as well as new mounts and bump stops. I will be keeping the original springs.
    https://www.koni.com/en-US/Cars/Prod...pecial-Active/
  1. Sport Suspension..
    By MarkM5 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 03-30-2001, 02:01 PM
  2. Suspension Question in 328is
    By 540Rob in forum 1991 - 1999 (E36)
    Last Post: 03-12-2001, 09:16 PM
  3. Will 1996 328is suspension fit my 1992 325i
    By BimmerXTC in forum 1991 - 1999 (E36)
    Last Post: 03-11-2001, 04:10 PM
  4. Suspension Install Questions...
    By joeyc in forum 1991 - 1999 (E36)
    Last Post: 03-08-2001, 11:50 PM
  5. Suspension Poll
    By Dinan M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-03-2001, 07:09 PM
