Results 1 to 3 of 3
Thread: Needed - Connector for Single Wire O2 Sensor
    Georgia
    '02 325ci & '74 2002
    I have a 1983 E24 633CSI and am looking for the connector between the Oxygen (O2) Sensor (one wire) and the wiring harness located in the passenger aft corner of the engine compartment. The connector disintegrated when I disconnected it. I am unable to even find a part number for it and it might be NLA. I can attach it without the connector but would like to do it correctly. It fits into approx. 15 mm hole in a bracket.
    Thx, Dan
    Georgia
    Since I can't find an OEM replacement, I will use the part below which is available on Amazon. If anyone needs one, I had to buy 5.
    Waterproof PG9 Cable Gland Plastic Cable Glands Joints Adjustable Connector Black for 4-8mm Dia Cable
    NYC & Long Island & So FL
    '93 740il '84 633Csi
    Although you have solved your problem, Molex makes a wide variety of connectors. Digikey is a good source.
    Sent from my SM-G955U using Tapatalk
  1. I need a 4-wire O2 sensor plug for an E30!!
    By acolella76 in forum Georgia sponsored by Harrison Motorsports
    Last Post: 07-29-2011, 11:57 PM
  2. Replies: 9
    Last Post: 09-24-2007, 12:14 PM
  3. Will 4 Wire O2 Sensor Work With 3 Wire Connection?
    By Anden411 in forum 1991 - 1999 (E36)
    Last Post: 05-26-2006, 01:56 PM
  4. Need to use Wide Band O2 Sensor!!!!
    By lflaco in forum Hawaii & Other Islands
    Last Post: 02-24-2006, 02:34 AM
  5. Need some help with deciding O2 sensor
    By mackle in forum 1991 - 1999 (E36)
    Last Post: 05-08-2005, 02:18 AM
