Results 1 to 11 of 11
Thread: Putting my 745i back together - need some guidance please
    Feb 2008
    Calgary, AB, Canada
    BMW 850, Alpina B10 Biturbo, Alpina B12 5.0
    Hey Everyone,
    It has been ages since I posted on here and it has been ages since I have had a chance to work on my 745i. I am now finally able to work on it and have been reassembling the engine after doing valve adjustments and going through the ignition system. Problem is that was started 3 years ago (shame on me I know) and my memory is failing me on these two wires. I just can't figure out what the heck they go to! I test fired the car today and it ran smoothly aside from the water pump making noises (needs replacing, parts en route). So these are not critical for the engine to run but they must have a purpose and it bugs me they are just sitting there.
    Additionally can someone point to where all the grounding straps go? I have one leftover that I can't figure out where it goes - about 8" long with loops for bolts to go through on either end. I know one goes on the end of the valve cover on the right side, but not sure where this one was placed.
    Finally, does someone have a vacuum line diagram I could follow to ensure I have all the hoses and that they are going to the correct places?
    Anyway - here's the pic of the mystery wires. They come out of the big group of wires along the fuel injector rail.
    Many thanks in advance!
    The kids:
    Alpinas: 91 E34 B10 Biturbo; 91 E32 B12 5.0; 91 E34 B10 3.0 Allrad (mom's car); '91 B10 3.5
    Bimmers: 91 E31 850; 93 E34 525i w/ aftermarket turbo; '01 X5 4.4; 93 E31 850i Dinan TT; 89 E32 750il Dinan TT; 92 750il w/ S70 engine and transmission
    Mercedes: 92 600sel; 93 S600 Lorinser
    VW: 04 Jetta GLS TDI
    Jun 2010
    TX
    1983/84/85 745i
    Coolant sensor wires.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Feb 2008
    Calgary, AB, Canada
    Thank you hitman - I thought that was what they looked like, from other BMWs, but wasn't sure. Are they just lose like that or supposed to be in some sort out connector or boot?
    The kids:
    Jun 2010
    TX
    1983/84/85 745i
    Little connectors is correct. Slips on the sender for cluster gauge.
    Feb 2008
    Calgary, AB, Canada
    I couldn't or the life of me figure out where the sensor wires attached and then I noticed this:
    Pretty sure that the car didn't come with that plug seeing as there are no other places these wires could attach. Is this in fact where the coolant sensor for the dash goes?
    The kids:
    Feb 2008
    Calgary, AB, Canada
    Duh - I just realized that what I thought was a wire holder are the pins to the sensor 🤣🤣🤣
    Jun 2010
    TX
    1983/84/85 745i
    Better late than never. Hahaha
    Is that a stack of washers on that thermo housing fastener?
    Either way, grab the 'A' model when you can. Apparently this is the latest and greatest casting which helps to distribute coolant more evenly.
    130mm water pump pulley is a given too.
    Feb 2008
    Calgary, AB, Canada
    Sorry for the slow reply, in the middle of packing up our house and trying to get this old girl back on her feet.
    Yes indeed I now have a surplus of washers, anyone need one? Lol someone had been in there before and obviously lost a bolt and couldn’t bring themselves to buy a proper one. That’s all remedied now.
    Shoot I’m not sure what the pump size is but I made sure it had a metal impeller.
    Have to change all the belts today as one was looking quite suspect. Better to do them all at once. Hoping to get her running today and bleed the system. Then idle for an hour to circulate the hell out of the tranny fluid as it has not been on the road in over 10 years.
    Feel free to throw out suggestions of other things to check, here’s what I’ve done:
    - Valves
    - oil and filter
    - air filter
    - intercooler cleaned out
    - ignition system done (new plugs, spark plug wire check and replace as needed, new coil, cap and distributor)
    - Tranny fluid checked - clean and correct level
    - fuel filter
    - HYDRAULIC SYSTEM FILTER - be sure to check yours, mine was mushroomed and cutting off circulation to the steering pump
    - inspected vacuum lines that I can see but will be replacing once at new digs
    - waterpump, thermostat replaced and coolant flushed
    - all calipers pulled and rebuilt (two were seized)
    - suspension inspected - seems ok but road test the true tell
    That’s all I can think of at the moment so please chime in if there’s anything else you recommend before our maiden voyage!
    Cheers
    Jun 2010
    TX
    1983/84/85 745i
    Try to stay out of full throttle until you fix vac lines and dial in AFM. You want 14:1 on your wideband at hot idle, around 850rpm.
    Do not have one? Time to buy one.
    Feb 2008
    Calgary, AB, Canada
    Duly noted thank you. I plan to go east on her for the first bit. Will definitely invest in a wideband. What other gauges do you recommend
    Dec 2011
    Edmond, OK
    00 MRoadster '83 745i,
    In addition to the AFR gauge, I have an oil temp gauge and a boost/vac gauge and a fuel pressure gauge in mine. If something is amiss, I can usually tell right away.
  1. Need help putting my E21 back together in san gabriel valley Ca
    By Bmwe34m5Guy in forum 1975 - 1983 (E21)
    Last Post: 06-05-2013, 10:10 PM
  2. Little Help Putting This Wheel Back Together...
    By Cha Ching in forum 1983 - 1991 (E30)
    Last Post: 01-30-2009, 11:43 AM
  3. Replies: 4
    Last Post: 11-03-2007, 05:37 PM
  4. Putting the computer back together
    By Fleksta in forum 1983 - 1991 (E30)
    Last Post: 10-27-2006, 04:02 PM
  5. HELP!Im a bit Stuck Putting M3 Shock back together!!
    By and1c in forum 1992 - 1999 M3 (E36)
    Last Post: 10-16-2005, 06:26 PM
