Results 1 to 5 of 5
Thread: 735i oil leak from driver side / middle, rear of engine
    Dec 2021
    nyc
    1988 BMW 735i
    Noticed a funny leak on the engine. It’s on the passenger side, middle to rear of the engine block, right under the starter.
    New valve cover gasket and no leaks I can see.
    I also have a power steering leak, but noticing I’m leaking both PS fluid and engine oil.
    Any thoughts what could be causing this?
    Pics:
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    chain tensioner gasket #24? http://bmwfans.info/parts-catalog/E3..._timing_chain/
    or this? quick-fix-for-m30-engine-oil-leak https://www.evansweb.info/2003/02/19...gine-oil-leak/
    but that is more to the front
    Dec 2021
    nyc
    1988 BMW 735i
    Hmm thanks shogun. Front is relatively dry, so maybe something else
    May 2020
    Poland
    E32 1989 730iA M30
    There are few pipes like Crank Vent Tube going from valve cover. Usually it is wet inside. I would imagine it might drop some oil when not properly seated. Gas dripping from fuel line? You said it is oil, gas would evaporate in seconds.
    Cover gasket not fully seated? And finally manifold gasket damaged, but again, rather gas than oil.
    One more idea: ATF from steering system is spread under high pressure from steering system bango bolt onto engine block.
    Dec 2021
    nyc
    1988 BMW 735i
    Found the leak. It was the oil pressure switch on the head.
    Part number: 12618611273
  1. Oil leak on drivers side
    By kidynomite in forum 1991 - 1999 (E36)
    Last Post: 07-19-2015, 11:17 PM
  2. Oil leak on drivers side
    Last Post: 07-19-2015, 08:35 AM
  3. Oil Leak From ?? Driver side forward end
    By ddbutton in forum 1999 - 2006 (E46)
    Last Post: 07-31-2013, 04:18 PM
  4. Oil leak around drivers side engine mount (US)
    By alexseiji in forum 1992 - 1999 M3 (E36)
    Last Post: 06-24-2012, 05:21 PM
  5. 2000 x5 engine oil leak from drivers side
    By bass528 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 02-27-2012, 09:35 PM
