RM European Auto Parts
Results 1 to 10 of 10
Thread: Issue With Rich Fuel Mixture
    Dec 2022
    Ontario, Canada
    2017 BMW 540ix
    I have a 2017 540ix with issues. I live 1500 kms (round trip) from my dealership. After returning home from having work done, the engine light comes on. So far two trips have been made. It has been diagnosed that my cyl 3 is missing due to a high fuel mixture.
    My first visit to the dealership found these issues:
    - faults for crank case ventilation system
    - cyl3 mixture deviation
    - fuel vent valve faulty
    - venturri nozzle faulty
    Work performed replace fuel vent valve and second inlet.
    There is no mention of work done to the Venturri nozzle. Is this covered in the work they did?
    On my second visit the following was found:
    - fault CYL 3 mixture control
    - air leak at intake pipe on turbo charger
    Work performed: replace intake pipe seal at turbo charger
    No work performed on cyl 3
    Shortly after returning home the check engine light has returned.
    Can anyone offer suggestions?
    Jul 2004
    Houston, TX
    36 Cylinders
    Do you have the actual codes that were read too?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    without codes we are just guessing, so my guess is not enough oxygen storage
    PRICE CUT on ALL FABRICS
    Dec 2022
    Ontario, Canada
    2017 BMW 540ix
    I'll see if I can retrieve them, thanks
    Dec 2022
    Ontario, Canada
    2017 BMW 540ix
    Here's the Code that pertains to my issue - 20E120.
    I have other codes but they pertain to the cameras and seat ventilation.
    Jul 2004
    Houston, TX
    36 Cylinders
    20E120 = crank case ventilation, ventilation hose: not connected/defect
    -Abel
    Dec 2022
    Ontario, Canada
    2017 BMW 540ix
    They replaced the fuel vent valve. The code was present after the work was completed.
    Jun 2012
    San Antonio, TX
    1995 BMW M3 Coupe
    Crankcase ventilation (CCV) is NOT fuel tank ventilation. It sounds like you have a cracked/broken vacuum hose under the hood that’s part of the CCV system.
    https://www.realoem.com/bmw/enUS/sho...diagId=11_6425
    Jul 2004
    Houston, TX
    36 Cylinders
    So is the ventilation hose still disconnected, or possibly damaged?
    Also, is the mixture truly running rich?
    If it is, then I'd have them look/replace that specific injector.
    However, these cars will easily throw a mixture deviation fault code, so I'm at a bit of a loss what's going on, so far.
    -Abel
    Dec 2022
    Ontario, Canada
    2017 BMW 540ix
    I was told by two mechanic friends about the rich mixture and my tail pipes are showing telltale signs.
    I could be wrong but work performed so far covers what should be a multi cylinder issue. Both visits showed that Cyl 3 was faulty. No work seems to have been done to that individual cylinder.
  1. Reoccurring Issues - Rich fuel mixture
    By MPP147 in forum 2017+ (G30)
    Last Post: 12-15-2022, 06:30 PM
  2. '84 325e running rich. Fuel Pressure issue?
    By txzaphod in forum 1983 - 1991 (E30)
    Last Post: 09-10-2019, 12:58 AM
  3. rich fuel mixture
    By bimmerrican in forum 1991 - 1999 (E36)
    Last Post: 11-24-2012, 11:25 AM
  4. Fuel Pressure issues and rich AFRs
    By uconnr in forum Forced Induction
    Last Post: 04-19-2012, 10:50 AM
  5. fuel mixture issues
    By Yonkers320is in forum 1975 - 1983 (E21)
    Last Post: 09-11-2004, 09:05 PM
