Results 1 to 12 of 12
Thread: Glovebox Flashlight
    Dec 2020
    Charleston, SC
    1988 BMW M6
    Glovebox Flashlight
    I have been thinking about converting my flashlight to LED. I am struggling to separate the flashlight from the holder/charger. Does anyone have any ideas on how to separate these two pieces without damaging them?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Just pull and wiggle, probably oxidized pins.
    To separate the flashlight, just split it in the middle, I once made a modification many years ago when mobile telephones were up to date, no smartphones yet, scroll down here ttp://bmwe32.masscom.net/johan/tips_tricks/tips_tricks.html
    here more about disassembling http://www.meeknet.co.uk/E32/Torch/Index.htm
    https://www.evansweb.info/2003/01/20...-modification/
    Feb 2009
    Pittsburgh, PA
    '86 635CSi, '08 128i
    Like Shogun says, pull and wiggle until it pops out. I've had that work about half the time, but the rest never came apart. I've tried penetrant, alcohol and distilled water, none were remotely successful. I'm told that a totally discharged NiCd will vent water vapor, so I suspect it's just galvanic corrosion. Now that you've got me thinking about it, I'd suspect a few hours in a warm & dilute acid bath like vinegar or an organic chealtor like diluted Metal Rescue/EvapoRust might do the trick.
    I'd be tempted to use very gentle heat, like about 150degF (65degC), but I'm not sure about how badly it would age the plastics. Also, neither NiMH nor Ni-Cd secondary cells are very happy about being warmed up.
    Save the manuals!
    '08 128i 6MT, '86 635CSi 5MT (B32, Motronic 1.3, WBO2, G265, 18# FW, 3.46 torsen)
    Past projects:
    '96 318iS, sold 4/23 '90 535iM, RIP 1/23 '90 535iA RIP 6/22 '91 318i, sold 7/19 '97 M3 sedan, sold 11/18 '85 735i, RIP 2/18 '92 325iC, sold 7/16 '91 318iS, sold 6/16 '84 745i, sold 10/14 '82 633CSi, traded 9/12 '90 325i, RIP '87 325 sold '89 525i, traded '87 325iS, RIP
    Dec 2020
    Charleston, SC
    1988 BMW M6
    Thanks guys. I’ve been trying the wiggle and pull method for the last two days and I’m not sure I’ve made much progress. I really don’t want to damage the base so I’ve avoided using penetrants. I don’t think I’ve ever seen the holder/charger for sale which is why I’m trying to be careful with it. I really want to try the vinegar but just can’t bring myself to do it yet. Thanks again for the suggestions.
    Aug 2008
    Sydney Australa
    1x633, 1x E3 2 DR Racer
    I had mine converted to LED and battery power. Works a treat!
    1977 633 CSi RHD Euro. S38B38 3.9L M5 Transplant. 5 Speed Getrag Dogleg. 3.73 LSD. 417hp, 369lb/ft
    1971 3.0CS E3 2dr Alpina Special Coupe Racer, 347hp, 295lb/ft
    Dec 2004
    Baja Sur MX & Healdsburg
    Coupes
    Acculux Torch
    White vinegar works great.
    Place entire assembly in a receptacle tall enough that it will not tip over then immerse the torch lens end up & black charge port end down so that the vinegar level covers the charge port only.
    Let soak for several hours if needed. Makes cleaning the male/female contacts a breeze.
    Ive rescued several of these Acculux torches both white & black version that BMW used. LED conversion & battery replacement is straightforward as well.
    DV
    ////// Motorsports & Vintage Coupes
    ALPINA Oldtimers of Course...
    BMW-Classic CCA
    Feb 2009
    Pittsburgh, PA
    I'd use red wine vinegar. Works just as well, plus it gives your car that fresh salad smell.
    Save the manuals!
    Past projects:
    Dec 2020
    Charleston, SC
    1988 BMW M6
    This is perfect. I will give it a shot this weekend and report back. Divad - you don’t have a write up on the conversion do you?
    Thanks again!
    Dec 2020
    Charleston, SC
    1988 BMW M6
    Just a quick update…I’ve had this thing sitting in vinegar off and on for the past couple of days and I’m still struggling to get it apart. It’s definitely working as the vinegar is turning blue but I still can’t get it apart. I’m going to put it back in now and let it sit there until I go to bed. I’m going to keep trying.
    Boston, Ma
    86 635,72 E3, 88M6,73 E9
    Swap out the vinegar, bring in some new H+
    Rob E3
    Dec 2004
    Coupes
    Soaking in White Vinegar could take several days, Ive no experience using H2o2 or Red Wine Vinegar...
    Here's a link to the Torch Mod's, https://www.bimmerfest.com/threads/b...m-cell.704409/
    DV
    BMW-Classic CCA
    Apr 2008
    Allentown, PA
    '03 M5; '98 911 C2S
    [QUOTE=dlvad;30850484]Soaking in White Vinegar could take several days
    +1 Patience is sometimes necessary with white vinegar
    E24: moved to a new caretaker
  1. glovebox flashlight question
    By rwm514 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-25-2004, 03:34 PM
  2. BMW glovebox flashlight
    By havenlock in forum BMW Parts For Sale
    Last Post: 12-26-2002, 12:14 PM
  3. FS: M-tec shift knob and glovebox flashlight
    Last Post: 12-19-2002, 01:45 PM
  4. 3 Rechargeable BMW Glovebox Flashlight FOR SALE!!
    By rollnbmwdroptop in forum BMW Parts For Sale
    Last Post: 11-03-2002, 08:43 PM
  5. Best place to buy glovebox flashlight?
    By DSK M3/4 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-13-2001, 08:19 PM
