Hi guys, my first post from here in the UK.
My early (June) '98 523i developed a slight coolant leak recently & I have traced it to seepage from the base of the expansion tank.
I see from OEM that there is a seal at the point where the tank sits in the base, is this likely to be the cause of the leak or would it be advisable to replace the tank itself, together with the cap & all seals?
I need the work to be done by my local garage (shop to you guys?) so as I'm paying for labour I need the problem sorted in one hit.
Thanks all for any advice.
Buy new
New. They are cheap. You will become very adept at changing them out. That and the radiator.
Before I upgraded to Z-ville, all- aluminum, I traveled with tools, coolant, expansion tank and radiator spares in the trunk.
Replace the tank, cap, and hoses including the little one hidden on top of the radiator. Replace the rad, belts, WP etc if not done previously
Current Garage Highlights
2003 525iT TiSilver
2002 M5 TiSilver
Former Garage Highlights
2005 X5 4.8is
2004 325iTs (2x)
1973 Pantera L
1969 Road Runner 383
Many thanks for all the advice, guys.
Would Febi be an acceptable brand name for the tank & what about changing to a reduced pressure cap?
I am retired & don't cover many miles these days, usually no more than 5000 in a year.
They're called "explosion bottles" for a reason.. I replace with OEM.
Keep it below the marker. I run with the top of the red stick sitting 1 inch below the base of the neck. Leaves more room for thermal expansion. You are talking about a few ounces of coolant difference.
I have two follow-on questions related to my '98 540i V8:
1. Coolant level 1" below the neck WHEN COLD, correct?
2. I have a small leak where the barbed nipple for the vent hose come out of the top, driver side of the radiator (before it goes across the radiator to the expansion tank). It's clearly NOT from the hose/barb connection. It looks as though that barb is pushed into the top of the radiator - there's a visible seam there and it almost looks like there are two tabs that could be release to pull it out. But I dare not try. I've looked at RealOEM. The diagram there doesn't match my configuration as it shows the nipple coming off the back, not the top. There's no part number, etc. Is it possible that nipple is removable and there's an O-ring in there? Or do I need to replace the whole radiator for this little drip? Ok, that was really three questions.
That's right where they break sadly. Mine was part of the radiator and not a separate fitting. New radiator was required for me.
I had a leak at the plastic nipple for the radiator return hose. It has an o-ring that tends to flatten out over time. I got mine out by pulling up and twisting the nipple. I've read that you can remove the coolant hose and reach in with a 10mm socket to squeeze the tabs that hold it in place. Replacing the nipple solved my leak.
2000 528i sport
EMP Stewart water pump
Dice iPod adapter
Alpine amplifiers
MB Quart speakers
MTX BGE12 subwoofer
AudioControl EQL equalizer
Wow... Mine is molded in. Probably difference in model years.
