Results 1 to 15 of 15
Thread: ASC+T and Cruise Control Issue
    Sep 2022
    Italy
    1991 E31 M70
    Hi everybody,
    as in the object of this 3D, I got an 850i '91 which has a double problem with ASC+T light always on and the Cruise Control not working.
    I think I'll change all the parts involved so I was looking for the ASC+T unit and I can't understand which one is correct between 34510026458 or 34511163086.
    Moreover I would like to understand if the Cruise Control problem will be fixed once I change the ASC+T unit or if the 850i has a proper and its own actuator.
    I thank you in advance for the support!
    Ciao
    Marco
    San Ramon, CA
    850Ci, M5, Model-S P85D
    I anticipate the ABS system does not activate either?
    The Stability control and ABS System use the same ASC module and brake line pump unit.
    Why not use a DIS or other BMW diagnostic tool to read out the fault codes.
    Then you can address the actual fault code issues and failures rather than using the shotgun approach.
    The Bosch control modules are solid and rarely fail.
    It is possible to replace the control modules and it still won't work.
    The actual problem could be as simple as a required cleaning of the axle hubs segmented transducer and ABS pickups at all 4 wheels.
    That needs to be done anyway when their are problems with the ASC/ABS system, as the wheel pickups are subject to road dirt, axle lubricants and the pickup itself is magnetic.
    Have Fun..
    Sep 2022
    Italy
    1991 E31 M70
    Hi m6bigdog,
    thank you for your reply, I confirm you the ABS system works.
    When you talk about the transducer you mean this (https://www.youtube.com/watch?v=KABf...erProduction)?
    I already went to an BMW concessionaire to make a diagnosis but unfortunately they didn't have an old and appropriate DIS in order to read all the errors.
    The shotgun approach idea comes from the fact that the previous owner disconnected the cable behind the dashboard to turn off the ASC dash error light, thus I am thinking he gave up to fix the problem because he probably it would be a more demanding than the expected.
    So I am thinking to replace all the parts involved with Asc+T and cruise control issues and I would like to ask you if I only should replace the ASC unit or if there are other parts involved.
    Thank you in advance
    Marco
    San Ramon, CA
    Quote Originally Posted by kacko View Post
    Hi m6bigdog,
    Marco
    Wholesale replacing parts rarely fixes the problem.
    These cars are complex and the shotgun approach just gets money spent and the system still doesn't work or worse, you introduce more problems.
    I suggest reconnecting the wiring and check the Instrument cluster indicator lights bulbs to insure all work then get a Diagnostic readout performed!!
    Without it you will just spend money with little if any results.
    Yes, that transduce needs to be cleaned but so does the hub segmented ring that requires removing the brake rotors.
    Also, the 1992 is the year the front hub was changed 3/92 from 97mm to 83mm and if someone installed the 83mm when your car is OE 97mm hub cleaning doesn't help.
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    First order of business is to verify the tire circumferences are equal. What size tires do you have front/ back?
    '91 850i 6sp (mint) (sold)
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Hi m6bigdog,
    Marco
    Also, remove the headlight and verify all the abs wiring is intact. I have seen those wires get chewed up by rodents.
    Without the diagnostics system you are shooting blind.... this is what you need: https://www.bimmerforums.com/forum/s...nostics-system
    Oct 2008
    Mt. Dora, Florida
    CSi#18, Tesla S85
    I have isolated my leak from the ASC+T unit under the brake M/C and will be rebuilding it after the first of the year.
    CSi #18 - Car & Driver Magazine 1994 actual test car
    -- Hellrot/Black-Gray (1 of 1 NA CSi color combination)
    BMWCCA E31 Chapter International Clubs Liaison
    North America Representative, 8er.or Board of Directors
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Well done Roger, good find!
    My BMW Repair YouTube Channel
    Jan 2019
    Finland
    1991 BMW 850i manual
    The ABS / ASC blink code on the BMW E31
    Perform the following actions in sequence to run the blink test.
    - Press the brake pedal and the "ASC" switch at the same time
    - ignition "on"
    - Release the brake pedal and switch
    - ASC LIGHT starts to flash
    Now count the number of flashes and compare them in the table.
    BC 1 = no error
    BC 2 = EML error
    BC 3 = Motronic error (DME / EML)
    BC 4 = speed sensor error rear left
    BC 5 = speed sensor error rear right
    BC 6 = front right speed sensor error
    BC 7 = Front left speed sensor error
    BC 8 = ABS solenoid valve rear left
    BC 9 = ABS solenoid valve rear right
    BC10 = ABS solenoid valve front right
    BC11 = ABS solenoid valve front left
    BC12 = ASR plunger valve fault, rear left
    BC13 = ASR plunger valve fault, rear right
    BC14 = valve relay error
    BC15 = return pump fault
    BC16 = accumulator charging valve error
    BC17 = long-term pressure monitoring error (plug memory can no longer be loaded)
    BC18 = leakage error (plunger accumulator discharges implausibly)
    BC19 = printing error
    BC20 = gear influencing line fault
    BC21 = ABS / ASR control device error
    BC22 = TD signal error (missing speedometer A signal on the control unit)
    BC23 = Option pin line error
    Sep 2022
    Italy
    1991 E31 M70
    Quote Originally Posted by cartoonz View Post
    Ciao cartoonz,
    thank for your reply! The tyre are 235/50 ZR16 95W, both front and rear.
    Now the dashboard ASC light went off and if I push the ASC button it reappears.
    By the way the Cruise Control still doesn't work, could this issue be connected to the ASC unit or something else?
    Sep 2022
    Italy
    1991 E31 M70
    Quote Originally Posted by m6bigdog View Post
    Ciao m6bigdog,
    I'll try with the Sl350's procedure to understand which code error could it be since it's difficult to me reach a place with a proper DIS.
    Now the dashboard ASC light went off and if I push the ASC button it reappears and it looks like it fixed itself (finger crossed).
    Marco
    Sep 2008
    Santa Barbara
    ASC light should come on when you press the button, yes.
    If you have wheelspin (which may have been the case before) that will trigger it too.
    Cruise control is triggered by a few things... and unless everything is right, it will not work. Brake switch is a common issue for that.
    Really, you need to find a proper diagnostic computer to plug into the car and interrogate those systems - this is a far better way to figure out the issue than guessing.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    If you are using LED brake lights the cruise control will not work.......
    Sep 2022
    Italy
    1991 E31 M70
    Quote Originally Posted by sl350 View Post
    - ignition "on"
    BC 1 = no error
    BC 2 = EML error
    Ciao Timm, Cartoonz and SL350,
    I did the SL350's procedure and it turned out to be the problem number 17 "long-term pressure monitoring error (plug memory can no longer be loaded)" what can be the cause of the problem?
    Unfortunately the ASC light came back and now it doesn't turn off ):
    Grazie
    Marco
    Oct 2008
    Mt. Dora, Florida
    CSi#18, Tesla S85
    I have received the parts, and hope to start on the rebuild of my leaking ASC+T unit soon. First I will have to remove the brake booster/mc assembly.
  1. E31 ASC and Cruise Control Issue
    By kacko in forum 8 Series (E31)
    Last Post: 09-19-2022, 10:38 AM
  2. Cruise Control Issues 95 325ic
    By Camano Cabrio in forum 1991 - 1999 (E36)
    Last Post: 08-02-2005, 12:32 PM
  3. Cruise Control issues
    By smurfless in forum 1992 - 1999 M3 (E36)
    Last Post: 06-01-2005, 05:05 PM
  4. Turn signal,rear lights,cruise control issues???
    By Johnnyvolvo in forum 1983 - 1991 (E30)
    Last Post: 09-03-2004, 06:05 PM
  5. Brake Light Ground - Cruise Control Issue
    By CC Rider in forum 1983 - 1991 (E30)
    Last Post: 08-09-2004, 04:01 PM
