Trying to find a part # for the ABS control module for an '96 850. You can find one for a 7 series but I can't find one for an 8 series.
Basic control unit ABS/ASC+T - p.n: 34-52-1-090-919
8' E31, 850Ci, Coupe, M73, AUTO, EUR, (EG41) : Anti block system-control unit
8' E31, 850Ci, Coupe, M73, AUTO, USA, (EG43) : Anti block system-control unit
If you can post an image of the label on your ABS Control Unit and the case, I may be able to cross-reference the basic ABS module to other cars and then all that would be needed is to reprogram the module for the E31-M73.
I may be able to clone the memory from my ABS module and use it to program a surrogate module.
That is what I did for the E31-M73 Transmission Control Module, to make a non-existent Steptronic Sports Drive module available!! Now anyone with a E31-M73 can have the same M/S Steptronic SD function as the 840 and have one cheap!!
https://www.bimmerforums.com/forum/s...DONE-Wonderful
Anyway:
The reason you can't find any used ones, is there where only 360 or so cars in the 1995-1997 BMW E31 850's production with that module originally shipped to the US.
Maybe another 900 produced for Europe.
If you are absolutely sure that is the part you need then you can hope a new one is available from BMW.
Just search online for the best price!!
After that you could use eBay search and wait for a used one to show up and hope you win the suction.
