Looking for some inspiration regarding clean installs for subwoofer and amplifiers in e36 trunk! I admit i lack creative ability, i mean i still cannot even draw stick figures... i have my sound system installed, but im looking to route my cables neatly and RETAIN as much trunk space as possible. Most of the setups i see are amazing, but they completely or mostly render the trunk space full. Id love to see some pictures of yall setups, or good examples youve seen!
You need to post pics!
It's a bit like having your cake and eat it too.
My amp and sub setup in and E36 sedan with fold down rear seats;
-10" JL Audio sub in a box that sits on top of the battery, does not take any space into the center of the car, over the spare.
- Alpine 5-channel amp mounted underneath the rear deck, just to the inside of the passengers rear speaker. I also have a large capacitor mounted just over the rear right shock.
- I have 2, 3-way crossovers mounted to the factory amp bracket for the front speakers. It is behind the left side trunk liner and out of sight.
- I have a sound processor mounted to ^^^ trunk liner.
To do it over again, I would mount it to the drivers side of the spare tire in the large black plastic cover and the amp too. I would have a few 12v fans circulating air to them.
I have a sweet tooth.
Aj do you have an instagram id love to see what you did. Also what kind of watt rms does your 5 channel amp run? Does that power the sub as well as speakers?
