Hi all,
i have been trying to find the cause of I can not fill up the gas tank without the pump clicking off several times!!
I have replaced the canister with a new unit ($440) and checked all hoses by the drivers side wheel well..new gas cap and smoked tested.
I am still having the issue and believe that the charcoal container vent pipe maybe the culprit. I tested the one on my car by removing the hose that comes from the top of the gas tank and blowing through the the valve and while it did allow air through....if I blew too hard..the valve would close and prevent airflow. Im assuming the valve is partially working by allowing some or most of the air to escape from the gas tank to the pressure tank and then to the charcoal canister to vent to atmosphere. If anyone has changed this piece and corrected the early shut off issue..please let me know.
Rick
CHARCOAL CANISTER VENT VALVE PART #16131184242
