A while back I had INPA connected to my car and was able to access a few functions (though not the ECU, ugh). After that I noticed that headlights seemed to be aimed lower, but I thought maybe I was just losing my mind (entirely possible given what I went through trying to connect to the ECU).
Just now I came across a thread about automatic headlight aiming on E32's. I don't see any components for my year and model on Real OEM, but I'm thinking that's wrong after what I just discovered. So what's the deal here?
I have wrenched on vehicles with:
1 cylinder
2 cylinders
3 cylinders
4 cylinders
5 cylinders
6 cylinders
7 spoke wheels
8 cylinders
easy to check, with automatic headlight adjustment the headlights have an electric motor at the back of the headlights. #18 http://bmwfans.info/parts-catalog/E3...r_headlight_2/ iL with SLS rear axle never has headlight aim motors, as that is adjusted by the rear axle.
1 cylinder
2 cylinders
3 cylinders
4 cylinders
5 cylinders
6 cylinders
7 spoke wheels
8 cylinders
My 93 740il (vin DE84687) does not have headlight dipping or aiming. The car originally had SLS but removed when the shocks started leaking .
Sent from my SM-G955U using Tapatalk
1 cylinder
2 cylinders
3 cylinders
4 cylinders
5 cylinders
6 cylinders
7 spoke wheels
8 cylinders
Just noticed that headlight aiming unit is only shown under the Hella Xenon Light section on Real OEM and it's grayed out. What does that mean?
1 cylinder
2 cylinders
3 cylinders
4 cylinders
5 cylinders
6 cylinders
7 spoke wheels
8 cylinders
In Europe all E32 without SLS must have headlight aim system, and in case of original ex factory Xenon Light also. Does not matter if normal H1 bulbs (Europe) or Xenon, if no SLS: headlight aim system is necessary, otherwise the cars will not pass the bi-annual roadworthy test. When SLS is deleted, also headlight aim has to installed.
USA: I assume that was not required in USA and therefore the cars ex factory did not have that.
As your car did have SLS, it does not have headlight aim motors. If the headlight angle changed, then check the adjusting screws, maybe broken
EBA headlight beam motors installation http://www.e38.org/e32/headlight%20b...adjustment.pdf
HEADLIGHT REMOVAL AND REPAIRS http://www.meeknet.co.uk/e32/Lights/Index.htm
https://www.bimmerforums.com/forum/s...problem-solved
these usually break: HEADLIGHT ADJUSTING SCREW MOUTING CLIP 63121378639
and 1378368 https://www.fmw-tuning.de/bmw/5er-e3...ml?language=en
https://www.youtube.com/watch?v=UTVqLPL9zUs
I don't think any USA spec cars had the system. It's mandatory in Europe, but not there...
Chances are your headlights are just poorly aimed. Easy to rectify.
