hello again guys, its been a while since i dint post anything... its good to be back, you guys helped me alot on the last years, and I miss all this world...
so here we go again, my last engine didnt survive much, I didnt touch the car for a long time, but now decided build a new engine
The engine specs are:
M50B25TU Block
85mm forged pistons
135mm forged rods
M52B28 crankshaft
KS rod/main bearings
all ARP hardware
head is all stock, just rebuilded
the bottom end is already done, just waiting for the head to assembly everything
WhatsApp Image 2022-11-24 at 15.33.01.jpegWhatsApp Image 2022-11-24 at 15.33.01 (1).jpeg
already painted the engine bay too
I have a question, someone already removed the water plug on the front engine cover?
I dont have water heater lines, already plugged the water port on the back of the head, dont have water on the throttle body, and since the car will have a custom radiador I can do without this hose, since it just came directly from the engine cover to the bottom of the radiator, and is one less hose to leak...
can just cut and weld...
hello guys, how are you?
made some progress on last days, engine is on the bay..
hope the getrag can hold a little boost, is hard to find zf here...
blocked the water hose that I mentioned
isnt a easy job, dont know how much it weights but...
oil filter, tensioners and engine belt done, just waiting the head to start wiring the ecu
hope I can start it soon hehe
happy new year for all!
