I have a 2001 Z-3 and when getting ready to put it up for the season, suddenly I cannot open the hood. The interior cable release works fine, but when I press the secondary lever the hood will not open. I have tried to use a hook inserted through the grill and pull on the latch, which moves - but not enough to open the hood.
I've read about others grabbing onto and pulling out one of the grills, I'm not sure what would help since the problem is not with the cable. But it's now pretty cold in Maine and I'm concerned about breaking them. I can feel some of the clips through the grill, but not enough to get them to release.
I've done the YouTube and forum searches, but still not found a solution.
Thanks for any tips/suggestions.
Jay
Push "against" the lever, opposite the way you use it to open the hood, in order to bend it down slightly, then try again. If that doesn't work, try pushing down on the hood slightly while pulling the lever.
PRICE CUT on ALL FABRICS
The cable releases both latches. It's possible that the drivers side latch opened, but the passenger side didn't.
The hood pops up when I pull the inside lever, and I can get my hand on the secondary latch. It is that latch that feels like it’s not clearing and allowing the hood to open.
I’ll see if I can bend it as suggested, but it feels pretty solid and not sure how that will go.
I didn't realize that there was a difference. Mine does have two though.
I'm pretty sure all Z3s are supposed to have two cable-operated latches, one either side, and a central secondary latch. The primary one is the left of the car, which links with a short bowden cable to the right side. Sounds like you may have the right hand side missing.
My 2.3 has only one cable release and one hand latch, both on the driver's side.
Dave
A little old couple in a little old car
Your hood may be slightly out of alignment. My safety latch catches when I try to open but a little flex and it clears and opens.
I had same problem. Yes it may be the secondary latch that may be bent slightly (which can easily be bent back to correct position) but in my case the striker on the hood had unscrewed slightly and only took a simple screwdriver adjustment to fix. I think #11 in the diagram. When you get the hood open look at both strikers and you may find one needs to be adjusted. Normally screwed back in to shorten.
After you get the hood open see if one of the 2 strikers on the hood needs to be adjusted (#11 in diagram). If the striker is too long (easily shortened with a screwdriver) it will hang up in the latch mechanism and prevent the release. Of course bend back the hand the finger release plate if it got bent trying to open the hood due to the striker being out of adjustment.
I've never seen any z3 with a single hood latch. Perhaps someone broke it at some point and only reinstalled the main latch back in place?
There should be the hood open lever inside the car and the under hood lever at the main latch to open it once popped, but there is a cable from the main latch to the secondary latch on the other side and when the lever opens the main latch it also pulls the cable to the secondary latch to open it.
Sim, you are correct. My owner's manual has a lever latch on each side. I'll check in the spring for the other lever latch. It can't be operable if the hood opens. Thanks for the prompt.
Dave
I had the same problem the inside latch would pop the hook but could not open
It turn out one of the latches had loosen and unscrewed so when hood was pop it the hood didn't lift high enough for the pin two disengage
I had to pop the hood reach as best I could with channel locks pliers and managed to turn it enough so that the next time I pop the hood it would pop up high enough to opened
Once I got it open I tighten up the pins and secured the lock nut haven't had the problem since
Ever since the hood cable broke on my M5, I lubricate all latches with silicone spray, door, hood, trunk. Hoods pop and open like new! hope this helps
Regards,
Brian
Cave Creek, AZ
How did you get the hood open? I have tried to grab it with a hook tool but it still won't release. It feels like it's getting caught on the part of the mechanism that's on the chassis - and it looks too rugged to simply bend the part that's attached to the hood.
And please forgive my ignorance, but where is the diagram you referenced? Thanks!
My hood pops just fine when I pull the inside lever. It's the next step where I use the lever under the hood on the driver's side to fully release the hood that it doesn't work.
Yes that is what my hood did I could reach the lever under the hood but the pin had unscrewed just enough to allow hood to pop up , when you moved the lever under the hood one pin was catching enough not to let hood open but still pop up so you could reach the lever under the hood
I had to screw pin back into hood and tighten lock nut against the hood have not had a problem since
Its a 2 person job. Have someone pull and hold the inside hood release lever while you try to get the hood open. Sometimes this will add just enough clearance in the latch so the catch will clear and the hood can be opened. No guarantee but this worked for me.
So @Jaybrad what did you end up doing to open the hood?
