Results 1 to 8 of 8
Thread: Disable E30 MPG Gauge
    CT
    '90 Conv S14 M3 Tribute
    I have replaced E30 MPG Gauge & Tach with M3 Tach & Oil Temp Gauge. What has to be done to disable original E30 MPG Gauge?
    Regina, Sask, Canada
    82 320i 89 325i
    Quote Originally Posted by petercory View Post
    you list a much newer car in your profile.
    if you actually swapped a tach, it probably won't work proper going from a 4 to a 6. as far as the mpg gauge, it's garbage anyway and is more a novelty than anything.
    edit: i think it takes the signal off the tach if that helps.
    Sep 2003
    whippany NJ
    1990 325is, 1990 325i
    You'd need to use the 6 cylinder coding plug from the s38 to make the tach signal correct when going from 4 to 6 cylinder cars. For the oil temp you just need to get the temp sensor that the m3 uses and install it with wiring.
    CT
    I have the correct Coding Plug as well as the correct Oil Temp Sender; I just wanted to know what, if anything was required to disable/eliminate the MPG Gauge and if its elimination affects the Tach or anything else.
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    The tach and mpg gauge are both driven from the SI board. Looking at the 88 M3 diagrams, it looks like the tach is still driven from the SI board and the old mpg gauge pins are simply "not used"
    "Howdy, Folks!"
    CT
    Do I have to remove the wires going to those pins in the connector plug?
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    You don't have to do anything to an M3 cluster when you swap it in, other than install the correct coding plug for your engine and hook up the oil temp sensor. You do NOT need to do anything re: the econometer.
    Edit: To be 100% clear, you don't have to do anything to the cluster OR to the car wiring. Oil temp is a totally separate plug.
    2011 M3 Sedan
    2006 GMC Sierra 2500HD LBZ
    1999 323i GTS2
    1995 M3 - S50B32/S6S420G/3.91
    1990 325is
    1989 M3 - S54B32/GS6-37BZ
    Hers: 1996 Porsche 911 Turbo
    Hers: 1989 325iX
    CT
    Thanks for your detailed reply Nick - greatly appreciated
  1. MPG gauge causes my e30 to deacelerate weird issue help
    By josianjehu in forum 1983 - 1991 (E30)
    Last Post: 11-06-2019, 09:18 AM
  2. E30 Podi "Alpina Tribute" e30 vent gauge
    By MC Hammered in forum E30 Parts Classifieds
    Last Post: 05-19-2016, 05:11 PM
  3. E30 Tach & MPG Gauge Quit; Five Green Service Lights On
    By 510man in forum 1983 - 1991 (E30)
    Last Post: 12-25-2013, 05:45 PM
  4. E30 e30 Euro Gauge Cluster
    By Firedaemon21 in forum Car Audio & Electronics
    Last Post: 10-15-2010, 10:16 AM
  5. E30 E30 VDO Gauge Kit - Oil Pressure, Temp, Volts
    By Guerc in forum Engines, Performance Parts & Software
    Last Post: 09-04-2010, 08:59 PM
