Hey all, does anyone have an idea why my X5 e70 is leaning to right side? FYI, I have replaced both rear air suspension spring recently but not sure why my car is not levelled.
Assuming all air suspension components( air compressor, solenoid valve, height sensors, etc.) all working with no leaks...a ride height adjustment is indicated. This can be performed with a bmw bidirectional scanner, or with a standalone version of ISTA. There are many videos on youtube. This is a service function that does not involve coding. It is actually pretty easy but a dealer would charge a fortune. In ISTA you begin by entering the rim size, then actually measuring the rear wheel height from the top arch of the fender to the bottom of the rim. Enter these values. Then the process repeats for the front wheels depending on your suspention type. Basically that's all. The process is more detailed than my explanation but ISTA provides all the details. Hope this helps.
