Results 1 to 5 of 5
Thread: Correct way to detach these metal clips? Any general tips for the valve cover gasket?
    Feb 2009
    USA
    2001 530i (E39) 128k
    Awkwardly prying them to the side does not seem legit.
    Did BMW really make connectors that are this weird?
    https://youtu.be/Awyclpp8WYM?t=350
    Any other general tips for the N52 valve cover gasket job?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    You asking about the ones that connect the wiring harness to the injectors? Yes, that's the best way that I know of it to use a small flat tipped screwdriver, or a pick like they are using. Once the harness is fully disconnected, you can lift it out of the way.
    As for doing a valve cover, those shouldn't need to be removed, do you have an aluminum valve cover or a plastic one? If plastic, it's best to just replace it, for by now the CCV is clogged up and the cover will be warped and in 6-9 months you will be leaking again.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Feb 2009
    USA
    Seems like this forum is dead !
    I have no codes or idle issues, so I think PCV is fine.
    I will try the oil cap suction test today.
    Also, you do not need to replace the entire valve cover if the PCV is failed.
    You can replace just the circular PCV part for $20 off Amazon.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    I saw a video where a guy yanked on the injector harness and the entire harness came off with the clips attached. I wouldn't advise that method. That could've been luck, but I remember when I pulled on the harness on my old 240sx and the plastic housings stretched and the clips couldn't hold down the harness any longer. On my e46 I had to replace some injectors and I used a thin flathead screwdriver and slowly pried back the clips and when the harness came free, I immediately pushed in the clips so I didn't lose one. When it was time to mount the harness, I again slowly pried back the clips and gently mounted the harness. Patience is key.
    dworthy's Avatar
    Nov 2010
    Yes, if the CCV/PCV system has failed, you will need a new valve cover as it's built into it.
    Darin
    Current:
    Past:
    M-Flight Member
  1. E39 549 valve cover gasket replacment - the easy way
    By glens in forum 1996 - 2003 (E39)
    Last Post: 09-20-2022, 09:10 PM
  2. Replies: 51
    Last Post: 12-01-2013, 11:08 PM
  3. Any tips on replacing valve cover & intake gaskets
    By 1999750il in forum 1995 - 2001 (E38)
    Last Post: 10-22-2011, 01:05 PM
  4. any one have a obd2 valve cover laying around?
    By bloxsom in forum 1992 - 1999 M3 (E36)
    Last Post: 03-06-2007, 04:21 PM
  5. Replaced Valve cover gasket- Idle corrected
    By rmn in forum 1991 - 1999 (E36)
    Last Post: 01-25-2005, 08:04 PM
