Results 1 to 6 of 6
Thread: E34 blower motor
    Jul 2020
    Lebanon
    1989 BMW E34 525i m20b25
    E34 blower motor
    Hello everyone
    My blower motor in my car is so weak. All fan speeds work but they are so weak. On 1 there is barely air coming out, on 2 and 3 there is more air but it's not as it should be. What can the problem be?
    moroza's Avatar
    BFE
    E34T
    Old and worn-out motor, and/or old and worn-out wiring. If you can't get a new motor, an electrical repair shop should be able to replace the brushes and bearings of the existing one. WIT, you can clean up and tighten the wiring contacts. Replacing the wiring with new and heavier-gauge is something I recommend, but a bigger job.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    also clean the 2 blower cages outside on the motor shaft, could be full of leaves, also found a cage which got lose on the shaft and did not rotate much with the speed of the motor drive shaft.
    Or Mikey got stuck inside '-) http://www.bimmerboard.com/members/s...ouse%20001.jpg
    Also see my website below, click on fixes in the left index>>> Fixes - Climate systems
    click on
    Blower motor: large doc' file, write up by by Ross1 using a Benz motor and re-using the old blower cages
    Repair brushes in blower motor: no text many photos
    Removal of Blower
    Apr 2009
    Monroe MI
    2001 330ci, 1992 535i
    you’re an 89 so don’t think you have a cabin filter but that location might still be worth checking for debris. This is what mine looked like
    Sep 2012
    Tennessee
    '89 Bummer
    Viperocco, Did you harvest a rabbit out of there too? Maybe have some stew for dinner…
    I can’t make it out from the picture. Where exactly is that?
    Denver, CO
    Passenger footwell behind the carpeted panel.
    After the resistor "sword" is removed, you will have access to the area where the detritus resides.
    Bring a shop-vac. After removing the resistor, I plug it back in and power up the hvac fan and close all vents. All sorts of good stuff should come out.
  1. E34 Genuine BMW New Old Stock E32/E34 Blower Motor 64111388175
    By rbelton in forum E34 Classifieds (closing soon)
    Last Post: 02-26-2022, 01:03 PM
  2. WTB: E34 Blower Motor
    By sp33dbump in forum BMW Parts Wanted
    Last Post: 12-18-2006, 12:41 PM
  3. 525i e34 blower motor problems
    By soundguy in forum 1988 - 1996 (E34)
    Last Post: 12-04-2006, 10:24 AM
  4. WTB: E34 Blower Motor Resistor (SWORD)
    By lem0n in forum BMW Parts Wanted
    Last Post: 03-09-2005, 12:15 PM
  5. E34 Blower motor dead?
    By bmwpower in forum 1988 - 1996 (E34)
    Last Post: 11-10-2003, 07:16 PM
