Results 1 to 2 of 2
Thread: Headlights, Brake lights and interior lights don't turn off when key is removed
    Valenica, CA
    BMW 2004 M3
    I just got my car back after replacing the bumper. When I remove the key, all lights on the dash stay on, the headlights stay on and the brake lights stay on. The key fob stopped working and the button to lock/unlock inside the car also stopped working. Here is a short video. https://youtu.be/hzSzAJZ3gFY
    I tried reprogramming the key, no luck. Also disconnected the battery overnight as other threads I read suggested, also no luck. Any help is apprecitated.
    Car is a 2005 E46 M3 if that makes any difference.
    Jul 2003
    I dunno
    '90 Ford Tempo
    Did you scan for BMW codes?
    If the headlight module has failed, there should be a code.
    The comfort module would be scanned as
    If the ignition switch is bad, there may be a code also.
    If a shop did the work, then they should be acountable.
  1. Replies: 10
    Last Post: 02-17-2020, 03:22 PM
  2. NEED HELP, wiring city lights to interior lights.
    By filnguyen in forum 1988 - 1996 (E34)
    Last Post: 11-04-2014, 12:40 PM
  3. Replies: 5
    Last Post: 03-22-2013, 09:18 PM
  4. Hazzard lights and interior lights on, doors unlock
    By FredRC in forum 1996 - 2003 (E39)
    Last Post: 11-06-2012, 11:52 PM
  5. FS: E36 Light Grey Interior Light Parts
    By KLEENE36 in forum Exterior Lighting & Body Parts
    Last Post: 05-28-2007, 03:58 PM
