Results 1 to 8 of 8
Thread: how to bypass running loss valve
    Aug 2011
    Los Angeles
    my brother's ti
    anyone know how? I've had two tuners(rk tunes, 22rpd) tell me they cannot bypass CEL p1145 for the running loss valve. I would like to use a resistor in place of the valve.
    why do i need to bypass this valve? when motor-swapping e30's, the running loss valve is not needed. The DME stores code 1145 unless the valve is plugged in. Also, the part is NLA and I would prefer wiring in a resistor versus going to the junkyard.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Just plug the harness into the valve and put it anywhere it will fit. Cut down the ports on the valve if you need to minimize the size. I use an Aeromotive 13109 with a cut down stock regulator bypassed but plugged into the harness and no CEL or issues. Set the aftermarket regulator to 51-52 with the vacuum/boost line disconnected and then check to see that it pulls pressure down to 43-44 with around 20” vacuum and that it rises with boost if you are boosted. Mityvac works for this testing. If you don’t have a valve and are trying to avoid getting one, I can’t help you but you are probably right that a fixed resistor would work.
    Aug 2011
    Los Angeles
    my brother's ti
    Thank you for confirming I should be able to use a resistor.
    The motor swap cars I've done in the past I have the running loss valve mounted under the intake manifold, bypassed but the electrical plugged in to keep the CEL away. I have a couple more swaps lined up and I'm really hoping i can use a resistor instead of sourcing old parts.
    I wish I knew more about electrical, I'm sure there is a way to determine what resistor I need. I'll try to do some more searching on determining resistor values
    Jun 2005
    New England
    One source I read says the valve is open for 20 seconds on startup and then closes to make the system operate like a dead head non return system. Maybe the CEL is triggered only if the valve does not close. If so I would think you could just measure resistance on a valve after 20 seconds. But if the ECU check is more complicated then a resistor won’t work.
    Jul 2004
    Houston, TX
    36 Cylinders
    Can you please provide which ECU?
    And which engine for that matter?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Aug 2011
    Los Angeles
    my brother's ti
    ms41.1
    m52b28
    thanks in advance for any info
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    I'm not sure why this not out there, but you can easily turn off the DTC for running losses 3/2 valve with RomRaider. I turned off several OBD2 functions with RR when I put an S52 in a 1994 E36.
    [IMG][/IMG]
    Aug 2011
    Los Angeles
    my brother's ti
    Quote Originally Posted by AJLM34A View Post
    thanks for clarifying.
    the info is maybe not out there because it is a total no brainer if you know how to tune with RR. I wish i had the time to play around with that stuff and figure it out, but unfortunately, I don't.
    I don't know why the two tuners I've used can't just tune it out. I've had them both do reflashes for me and both tuners and both reflashes still had the DTC for running loss valve.
  1. Help please, Solenoid Valve (Running Losses) '95 E36 / M50
    By scottbujold in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-27-2013, 06:18 AM
  2. Replies: 1
    Last Post: 05-26-2013, 05:30 PM
  3. Replies: 4
    Last Post: 08-10-2008, 11:54 AM
  4. Running Losses?
    By Hawkster in forum 1991 - 1999 (E36)
    Last Post: 03-26-2006, 09:13 PM
  5. Can I safely bypass heater pump/valve on E32?
    By Ryan Stewart in forum 1988 - 1994 (E32)
    Last Post: 06-26-2003, 11:01 PM
