Results 1 to 4 of 4
Thread: cooked 91 850 eml
    Nov 2022
    malaga spain
    1991 850i,2005 m5 e60
    cooked 91 850 eml
    Hi all,
    I have just purchased a 91 850i.
    The last owner touched the body whilst doing up the positive and blew the EML and both engine ECUs.
    His mechanic found second hand ECUs and got each bank working separately now i imagine its just the EML.
    My issue is i cannot find Bosch 0 205 000 015 1733598, all other 850i and 7501 from the same year have different part numbers.
    My question is:
    can i use an EML from another 850/750 or does it have to be that exact part number?
    if it does come from another car will it need to be coded?
    Or worst case would getting all 3 from another car work?
    Aug 2011
    Germany
    05/1993 BMW 850CSi
    Hi bowlertomcat,
    the EMLs with the following numbers 0285006004, 0205000004, 0205000005, 0205000015, 0205000023 all consist of the same hardware. Only the software versions are different. The software versions can be adjusted either by replacing or reprogramming the EPROMs.
    Regards, Joachim
    Mar 2011
    Damascus, Maryland USA
    E31/E32 VWs Tesla
    Before you dump a bunch of money on new computers, Check that you have power in the EBox (the box with the EML/DME) it's possible that you just blew the fusible link in the trunk. (It's vinyl wrapped and not always obvious) You can cheat by jumping 12V from the B+ post to the + post in the EBox...
    '89 735i, '91 850i, '81 MB 380SLC (For Sale), Tesla Model 3, and VW Passat TDI -- Yes, I still repair General Modules, DM for info!
    Nov 2022
    malaga spain
    Thanks guys,
    managed to find the same eml and the car runs.
    now i have an issue with the car idling at around 2k rpm.
    any ideas?
  1. 91 850 maintenance
    By boomer3 in forum 8 Series (E31)
    Last Post: 10-05-2007, 03:50 PM
  2. Dynoed my 91 850 Yesterday
    By natehp in forum 8 Series (E31)
    Last Post: 08-14-2007, 06:29 PM
  3. will wheels with a 13 mm offset fit on a 91 850?
    By ///dustin in forum 8 Series (E31)
    Last Post: 07-26-2007, 07:11 PM
  4. thinking about a 91 850
    By skylinergtr in forum 8 Series (E31)
    Last Post: 07-23-2007, 12:49 PM
  5. parting out white 91 850 auto
    By niconvertible in forum 8 Series (E31)
    Last Post: 08-26-2006, 09:17 AM
