Results 1 to 7 of 7
Thread: Error codes
    Nov 2022
    Belguem
    f30
    Error codes
    Hi guys,
    may be somebody can help, following code errors on my f30 2013:
    CD0487
    E12C1A
    E7145C
    Jul 2004
    Houston, TX
    36 Cylinders
    Please identify the car exactly and the modules those errors came from.
    Also, what is wrong with the car?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    +1
    No descriptions with the codes means nothing.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Nov 2022
    Belguem
    f30
    Hi agian, f30 2013, error codes displaed in the Rheingold.
    Actually i already found some description on https://bmwfault.codes/
    E12C1A is Signal (central locking system and lid status, 0x2FC) invalid, transmitter CAS/BDC
    E7145C Integrated automatic heating / air conditioning system
    Now how to guess what is wrong? :-).
    Actually the E71445C is clear more or less, i have some not good sound when aircon is on, probable it may need replacement.
    But E12C1A is a mystery. Some thoughts?
    Jul 2004
    Houston, TX
    36 Cylinders
    If you're chasing codes and not an actual problem then these cars will keep you very busy. They will always have codes for a lot of stuff in the 20+ modules. Most are just old things that happened incidentally and it records. It's mostly worthless if nothing is actually wrong.
    I don't think those descriptions are correct.
    If you are using ISTA (so called "Rheingold"), why don't you use the Generate Test Plan and follow that? It has loads of information.
    -Abel
    Nov 2022
    new york
    2001 BMW 74oil
    Abel
    Do you still fix Bmw airbag modules that need to be reprogramed ?
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by 2001740il73 View Post
    Abel
    You should be sending a PM instead of posting in random threads
    I do them here and there, yes
    -Abel
  1. CE Error Code 51
    By BGM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-07-2013, 07:48 PM
  2. P1500 Error code(VSS intermittant)
    By Coop in forum Forced Induction
    Last Post: 01-21-2003, 06:37 PM
  3. Getting weird error codes when I have no problem???
    By AaronM3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-16-2003, 12:03 AM
  4. Help! Error code E9
    By lagvoid in forum 1992 - 1999 M3 (E36)
    Last Post: 09-22-2002, 10:23 PM
  5. Error code of 1-4-4-4
    By Dan in forum 1991 - 1999 (E36)
    Last Post: 09-06-2002, 12:42 AM
