Results 1 to 7 of 7
Thread: No crank no start
    Nov 2022
    Tennessee
    Bmw x3 2008
    No crank no start
    2008 BMW x3 would not Crack after I came out of store I can hear 2 clicks from the engine bay when I try to start but that's it can anyone help also the ignition switch has been changed to no avail AAA tried to jump it before towing but still nothing all dash lights come on window rolls down unlock lock works key is synced to vehicle car beeps when key is in ignition and door open at this point I'm lost only other thing I can think it to be is the starter can someone help
    Mar 2019
    ATLANTA GA
    456 X3s
    Quote Originally Posted by Coach423 View Post
    Does your 08 have the N52 engine?
    Nov 2022
    Tennessee
    Bmw x3 2008
    I think so it says 3.0 l si
    Nov 2022
    Tennessee
    Bmw x3 2008
    Yes n52 3.0 l s.i.
    Mar 2019
    ATLANTA GA
    456 X3s
    Sounds like braided ground straps need replacement and add an additional one as well...thats my two cents of experience.
    Cheers!
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    Quote Originally Posted by X3456 View Post
    Cheers!
    I get where your thinking is here. Bad ground can prevent the starter from getting enough current (amps) even if it has enough volts. I had a car do this once when the battery ground cable's chassis connection was loose.
    To the OP, it's a good idea to check the battery connections, battery ground, and engine ground straps. To be honest though, considering how suddenly it went out it's probably the starter.
    "Howdy, Folks!"
    May 2012
    FL
    E83, E21
    The first thing that should be done is load testing the battery before falling further down the diagnostic tree. Nothing on this car should be guesswork.
    E21 build
    BMW CCA 584213
    I buy socks from Amazon.
  1. Engine Swap, now crank no start.
    By bjl4776 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-28-2006, 11:43 AM
  2. :: M42 owners :: How many 'cranks' to start motor?
    By Matt at Dunlop in forum 1991 - 1999 (E36)
    Last Post: 11-09-2006, 03:13 PM
  3. All of a sudden, long cranking before start...
    By 99E36M in forum 1992 - 1999 M3 (E36)
    Last Post: 05-26-2006, 12:48 PM
  4. E32 long cranking to start
    By jim.edwards in forum 1988 - 1994 (E32)
    Last Post: 09-03-2003, 10:11 AM
  5. CRANK, CRANK no start. HELP!
    By martin23 in forum 1983 - 1991 (E30)
    Last Post: 04-14-2003, 03:37 PM
