Bavarian Soundwerks
Results 1 to 10 of 10
Thread: headunit wiring
    Apr 2019
    Norway
    94 325is coupe
    headunit wiring
    im running new speaker wires to aftermarket amp and headunit. does anyone know which wires from radio harness i need to connect? prolly only 4 or 5 wires as im not using oem speaker harness? e36.
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    You'd need constant and switched 12V, ground and remote control for your aftermarket radio:
    http://wedophones.com/Manuals/BMW/
    Sep 2008
    West London/Heathrow - UK
    03 530dT - Ex Police Car
    Hi,
    Given the seemingly limited knowledge and experience you have from your question, I'd suggest you find a local 12V electrionics or electrician to fit and connect the head unit, amplifier and speakers properly and most importantly, safely. For instance, have you got the correct guage wiring for the amplifier? have you got the right fuses and circuit breakers connected correctly too? same for the head unit power ? do you know exactly which wires in the car's harness are the correct ones to use on the new head unit wiring? Wiring diagrams are out there, but a previous owner may have spliced in other cables with different colour covers so you'll need to test and check before hand.
    I'm not saying this to deter you, but inexperience with 12V electronics install can and has led to fire's in cars and when the insurance have foud it was down to faulty wiring done by the owner, they've then not paid out.
    Get it all fitted by a local reputable installer !
    Cheers, Dennis!
    Apr 2019
    Norway
    94 325is coupe
    thx, yup inexperienced on audio, but done some research before i installed it. only headunit to go now and can try to see if it works.
    placed the amp in same location as the stock amp, and grounded of the chassis close to the amp. will try to upload a pic to see if its ok setup. i did all new speaker wires, away from any powerwires, and trid to keep connections clean and well routed with correct gauge and fuse location besides battery.
    Apr 2019
    Norway
    94 325is coupe
    Quote Originally Posted by Mless5 View Post
    awesome thx. only need to buy headunit now lol. been looking at Pioneer DEH S720DABAN, but out of stock everywhere.
    attached pics for my install. is location of amp and ground ok? :P
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Yes, you should be fine.
    Apr 2019
    Norway
    94 325is coupe
    thx boys, its appreciated.
    also i have another question; is there any good ground points in the trunk for the amp? maybe shock tower?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Check the left side of the trunk just aft the of the inner fender. There should be an audio ground lug there.
    Apr 2019
    Norway
    94 325is coupe
    awesome, will check that out, thx.
    Apr 2019
    Norway
    94 325is coupe
    edit: i got sound now, but not from the tweeters. possibly low voltage from battery make the amp go into some kind of safe mode?
    so i finally got my headunit and connected everything - but got no sound.
    amp and headunit turns on and is playing.
    wires seems to be good.
    my radio harness adapter has a 12v memory wire (yellow and red), to which i connected the yellow wire from my headunit. hopefully that is correct?
    also there is an orange illumination wire on the adapter that im not using.
  1. Ugh... I'm a n00b... headunit wiring help
    By Hugo in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-08-2007, 10:14 AM
  2. Got a new headunit, wiring suggestions.(long post)
    By jmejiaa in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 09-28-2006, 12:01 AM
  3. e36 headunit wiring help
    By racer00000 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-06-2006, 01:46 PM
  4. E30 Headunit Wiring for Greymarket 323i?
    By rem83 in forum 1983 - 1991 (E30)
    Last Post: 07-29-2005, 09:24 AM
  5. Aftermarket headunit wire harness adaptors?
    By Drea///M3 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-21-2003, 02:17 PM
