Results 1 to 3 of 3
Thread: SOLVED: 2011 BMW X3 F25 28i Transfer Box / Shuddering at Low Speed (137K Miles)
    Oct 2022
    Chula Vista, Ca.
    2011 BMW X3 F25 28i
    Thumbs up SOLVED: 2011 BMW X3 F25 28i Transfer Box / Shuddering at Low Speed (137K Miles)
    Hey all,
    Figured I would post this on a BMW forum to hopefully help someone out in the future. I have just recently acquired a good friend's used 2011 BMW X3 F25 28i and have been working to restore it to "reliable commuter status". It's a long story (see below) but he was initially convinced that his X3 had a bad transmission because it was shuddering while turning at low speed (pulling into parking spots, driving in parking lots, etc.).
    TLDR; Drained and inspected the transfer case fluid, it was PITCH BLACK (the worst I've seen) but no chunks of metal, refilled with fresh Triax DTF-1 fluid, used a bidirectional programmer to perform the relearn function on the transfer box, problem appears to be fixed.
    The rest of the story....
    My friend took it to one independent shop (that works on BMW, Mercedes and Audi) who changed the transmission fluid for him and told him if it didn't solve the issue that he would need to replace the transmission.
    Now, I'm a Jeep guy, try to do as much work on my own vehicles as possible and I needed a commuter. After hearing all of this, test driving the car and doing some research (using the internet as well as calling and visiting *3* local independent BMW only shops) on the symptoms it was obvious this was a driveline issue and not transmission related. I even mentioned this to my friend (and actually tried to talk him out of getting rid of the car) and he still wanted to sell the car (He bought a new M based X4 -- this may have been the real reason he was done with the X3). He made me a deal I couldn't refuse, so to speak, so I jumped at it and started working through the various issues a 137K mile N52 BMW has (replaced the valve cover and oil cooler seals which were leaking, replaced the serpentine belt and tensioner, cleaned and then decided to replace the vanos solenoids to sort out a rough cold start idle, etc.)
    I pretty much worked my way down to the driveline issues over the last few weeks. The three local BMW shops I spoke to all agreed on two things:
    1) It's definitely transfer case related
    2) We are happy to sell you / install one for you
    None of them suggested to simply change the fluid and put the box through the re-learn procedure. (although one did agree that this first step was a reasonable one after I suggested that I was going to try that first.
    Things I tried that DIDN'T fix the shuddering issues before changing the fluid:
    1) Inspected the drive shafts. I found the ujoint in the front DS was beginning to fail and found a new (serviceable replacement on amazon) and swapped it.
    2) Performed only the transfer box relearn procedure
    3) Sorted out the rough idle
    The fluid cost me ~$36 (Triax DTF-1) and the programmer was $129 (Elite Launch BMW Creader). Both were purchased on Amazon. I also purchased the replacement front driveshaft on amazon (and quite frankly it appears to be better made than the BMW equivalent and has the advantage of being serviceable.
    Let me tell you...if you're being told (by experts) that you need to replace your transfer box (at least in the Gen 2 F25 based X3) you have nothing to lose trying a fluid change and relearn procedure first. If you can jack your BMW up and get it safely on all four jack stands, you can do this job yourself.
    Hope this helps someone.
    Cheers!
    <D>
    Apr 2023
    Pittsburgh, PA
    2011 X3 28i - N52 - 113k
    Did the shudder stay away? I had to get an alignment after the transfer case fluid replacement before it stopped shuddering at low speeds.
    Jul 2021
    detroit
    2011 335i
    [QUOTE=dmulk;30836855]Hey all,
    I have the same issue with my E83. It happened only accelerating from stop. I replaced the drive chain and put in new DTF-1 fluid and issue gone. When oil got so dirty, the friction clutch plates don't function properly causing shuddering at low speed or accelerating at low speed. If you want to keep your vehicle for a long time, then don't listen to BMW BS it's life time fluid or 15k oil change internal. So many people got the engines, trans and transfer case destroyed because they followed BWM service interval.
  1. 2012 BMW X3 F25 Transfer Case drain plug
    By m3legend in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 10-25-2020, 08:44 AM
  2. Considering 2011 BMW X3 28I AWD for purchase any help?
    By Salacak in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 06-03-2020, 11:35 PM
  3. 2011 BMW X3 28i Xdrive Running Issues
    By alifeili in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-14-2018, 06:09 PM
  4. 2011 BMW X3 Xdrive 28i - No Longer Available
    By abhi234u in forum BMW Cars For Sale / Wanted
    Last Post: 06-16-2015, 11:18 AM
  5. 2011 BMW X3 28i
    By archer1247 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 12-26-2012, 06:41 PM
