Results 1 to 7 of 7
Thread: 86’ E23 L7 - Coolant Vapor From Vents & Total Coolant Loss From Engine Bay
    Oct 2022
    North Carolina
    1886 BMW L7
    First time poster!
    I have an 86’ L7 (E23) that I have been working on for many months. I recently customized the fuel system and took it for a spin after all of my hard work. As I was cruising around town, I noticed a small amount of condensation on the windshield. After a couple of minutes, I could actively see vapor coming from the dashboard defroster vents. I immediately pulled over and turned the car off. I got out of the car to find that a massive amount of coolant had spilled all over the ground. There was NO indication that it had spilled prior to me pulling over. It appears that it only spilled once I was stationary. DISCLAIMER: My AC/Heater hasn’t worked since I purchased the car. The climate control buttons do not stay depressed when I press them and I haven’t bothered prioritizing why it doesn’t work so I don’t believe that this issue is related to the use of my heater. I towed the car home and removed the radiator hose network from the expansion tank/heater core/front-of-engine and did not discover any damaged hoses.
    I’m at a loss and it’s frustrating to diagnose. My engine temp gauge doesn’t work so I’m afraid to drive the car until I can pinpoint where I’m losing coolant from.
    I hope to help contribute what knowledge I have to the this community in the future!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E23 sub forum
    Jun 2010
    TX
    1983/84/85 745i
    Sounds like your heater core has failed.
    Oct 2022
    North Carolina
    1886 BMW L7
    Is there a way to bypass it without removing the entire interior?
    Jun 2010
    TX
    1983/84/85 745i
    Yes. Pass side is your heater valve...connect a heater hose to the inlet to that, run across valve cover, hook it to the other line.
    It makes more sense looking at it.
    Oct 2022
    North Carolina
    1886 BMW L7
    I'll look into that and come back for additional advice w/ pics. Thank you!
    Jun 2005
    Oregon
    I had similar problem and it was the heater core. Replacing it was not easy but did get it done and so far no leaks
  1. E23 86 E23 735I for sale
    By pawk72 in forum 7 series
    Last Post: 03-03-2012, 05:01 PM
  2. E23 L7 Starting problems
    By eibowow in forum 1978 - 1987 (E23)
    Last Post: 01-18-2008, 02:59 PM
  3. Anyone parting out an e23 L7?
    By Cambridge in forum 1988 - 1994 (E32)
    Last Post: 08-19-2006, 04:03 PM
  4. Leaking coolant - should the vent screw be closed?
    By WheelsDirect in forum 1988 - 1996 (E34)
    Last Post: 07-30-2005, 07:23 PM
  5. 3.46 ring and pinion from e23 L7
    By khyleung in forum 1992 - 1999 M3 (E36)
    Last Post: 02-09-2005, 11:09 PM
