Ok, now I understand, I was confused. The residual heat system first came out with the 1995 E38, and then on to the ‘96 to 2000 E39. The IHKA systems with the MAX buttons, which came out in 2001, added the feature of how the AC system automatically adjusts itself to the different changing ambient temps while driving. So you want to change your residual heat system and add on the AC adjusting system, well, it’s clear now, you need to replace the panel to a newer panel with the MAX button. That was the new addition BMW implemented . The residual heat system still works the same, but did not come with the sensor, you need both the sensor and the MAX buttoned panel. I do not think you can retrofit the sensor and expect the older panel to have the programming to adjust the AC in the summer, the whole reason for Ryan’s thread on E39Source.
Stephen, if you move out to that area you said you were looking, when I come back from Joisey, I will be in that same vicinity!
well the weird thing is (as I mentioned in the first post) my panel (the older, rest buttoned panel) has the necessary setting coded in it, but it's disabled. I pulled the config file with ncs expert and there was this line: "solar sensor: disabled/enabled" I'm thinking of experimenting with it by enabling it after retrofitting the sensor and see if it really works. if not, I'll have to buy a max buttoned panel like everyone else.
Huh… Interesting. Try it out, then test and see if the AC goes colder to warmer shading the solar sensor.
