Results 1 to 12 of 12
Thread: Is the 525 to wimpy for a stick shift conversion?
    Nov 2007
    Justin Texas
    2003 525it 2003 X5 4.6is
    Still loving the “Chuck Wagon” looks good, drives very nice. The coldest AC of ANY car
    I have owned. It will actually make your face hurt if you let it blow on max cold.
    The auto tranny is working great, I’m just bored with 2 pedals.
    My question is the 2.5 engine just to slow to have a good time with a stick shift conversion?
    It’s a mid year 2003 nice example with 150K. No leaks, great body and interior.
    I plan on keep it for 5 more years, or so.
    And for those that have done this , 5 or 6 speed transmission?
    I will always own a BMW.
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    The 525 actually feels more alive with the five speed. The slush ox does just that, make it slushy. Stick with a five speed, and research what final gear you need to get. With the autos final gear at the diff, you will be running an extra thousand rpm while cruising at 65.
    Never thought about running a six speed using the stock auto final gear.
    Car-nation, WAH
    2002, e21, e30, e36, e46
    +1
    the 5 speed and a 3.23 or 3.15 diff is just fine. You have to keep revs up, but that's the fun part.
    and the 6 speed ought to be just about right for the auto diff ratio, right?
    t
    would put a 3l in while he was at it, but also thinks that an M54B30 is the answer to everything.
    Mar 2015
    Richmond, VA
    '99 540iAT; '00 528iT/5
    Not at all, the 525i/5 is a great drive! Nice and happy to rev up and with the right diff ratio it jumps off the line.
    1999 540iAT Glacier Green / Black
    2003 525iT/5 Oxford Green II / Beige
    2011 328i Conv. Platinum Bronze
    Jun 2013
    Boston, MA
    99 528i/5, 05 ZHP conv
    +1 on man swapping the 525i…I just posted this on bimmerfest.
    I daily drive an '03 530i sedan that I manual swapped 4 yrs ago. It runs great.
    The process to swap a 525i is identical to the 530i and it's the same sedan and wagon..
    mechanical, wiring (not much), Coding (not too bad) . Swapping a 540i is slightly different.
    The easiest trans for your 525i will be the 5-speed ZF S5D 320Z which was used in the 525i manual wagon and 530i sedan.
    But, you can also easily install the 5-speed Getrag S5D 250G( used in 525i sedan) in your 525it if you get the driveshaft that goes with it. ... Either one will work
    A 6-speed can be done, but it’s more work, and maybe 2x the cost.
    Here is what I would grab from a manual parts car for your swap :
    -Transmission
    -flywheel and clutch components
    -driveshaft
    -rear differential (don't use the one from an auto)
    -shifter assembly, boot and trim (top & bottom)
    -Transmission elect connector with a foot or more of slack
    -pedal box (clutch and brake)
    -clutch and brake switches on pedals (if any)
    -clutch master cylinder and it's switch
    -clutch slave cylinder
    -clutch line - rubber /steel
    -hose from brake reservoir to master cylinder
    -Big rubber grommet covering auto shifter hole in transmission tunnel (remove insulation from below)
    #1 Pro-tip.. Be sure to wire in the cruise control switch. If you don't you might have a rev hang...
    Here are a couple of links- search any add'l link referenced in these links
    Manual Swap 2003 525iT
    (particularly post #31)
    2003 530i Auto to Manual Swap
    Tavernier, Florida
    '99 2.8&Mcoupe, '03 Mini
    I’ve got all the parts to do an M54B30/37BZ 6 speed from an E46 330zhp into my ‘01 525ti. I’ve got to modify the driveshaft and fab a trans crossmember. Other than that, it mostly bolt-in. I’ll be using a tall diff from a 5 speed car.
    -Donny
    Tavernier, Florida
    I came across a 2000 5 speed 525i in a U-Pull yard today. Too bad it won’t be on the road again, but good parts to pick for a manual swap.
    -Donny
    Feb 2014
    Alexandria, VA
    Quote Originally Posted by KeysCoupe View Post
    -Donny
    You mean a 528, or a 540.
    Tavernier, Florida
    Quote Originally Posted by BimmrMeUpSnotty View Post
    No badges on the trunklid, and I didn’t look at the label in the door jamb, so I am probably mistaken. I went by the inventory tag on the quarter panel showing as a ‘00 525. Definitely a 6 cyl car, so probably a 528 as you say. What trans is that? ZF 320? I may go back and grab the 5 speed.
    There was also a ‘99 540 with a 6 speed. A 420G?
    -Donny
    Feb 2014
    Alexandria, VA
    Yep, if it’s a 2000 528, it will be the ZF320Z
    Tavernier, Florida
    I got back to the car with the 5 speed manual. It is a 525. The date on manufacture is 9/00, making it an ‘01 model year. The vin is WBADT33411GF40023 that confirms it came with a 5 speed.
    -Donny
    Jun 2013
    Boston, MA
    -Donny
    That means it will have a 5-speed Getrag S5D 250G, unless it is a touring.
  1. Replies: 2
    Last Post: 05-10-2017, 01:23 AM
  2. Replies: 0
    Last Post: 05-08-2017, 03:40 AM
  3. Removing Stick Shift Knob
    By Zolton in forum 1992 - 1999 M3 (E36)
    Last Post: 07-14-2010, 08:31 AM
  4. 525's , 530's in stick on cl...
    By 5senses in forum 1988 - 1996 (E34)
    Last Post: 02-20-2009, 12:02 AM
  5. Learning stick shift
    By stjobs in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-30-2004, 03:07 PM
