Good afternoon!
One of the brake lines in the engine bay of my M5 split when I was backing the car up. I had the car in reverse with my foot on the clutch. The clutch went to the floor and the car jumped into gear. Since then, I've replaced all 6 brake lines, and I'm now trying to bleed the system. The brakes are rock solid with no apparent air in the system after bleeding. The clutch is a different story. I've been trying to bleed it at the slave cylinder but cant seem to clear the air. The clutch pedal is basically dead. It wont come off the floor. Any ideas of where to go from here?
Thanks!
2002 M5 Sterling Gray (88k)
Dinan mufflers and intake, ZHP shift knob, E60 shifter, Ground Control coilovers
Restoration in progress!
2021 M340i (25k)
Sold!
2003 540i MSport 6sp Tit Silver (193k)
Dinan Exhaust, Autosolutions SSK, 88C Thermostat, Koni's, BlueBus, BavSound, DUDMD Stage 2, AFE CAI
Sold!
Aavi's 98 M3/4/5 Cosmos (137k)
TMS Stage 3 with Shrick cams, Shorty headers and tune, M50, Stromung, 8.5 LTW's squared, PFC-Z, 3.38, Bosch H1's with city lights, CD43, BSW Stage 1, BMS SSK, TMS Underdrive Pulleys, Sunroof Eclipse, LeatherZ gauge pack
BMW CCA# 308494
When bleeding the clutch you actually have to pull it up from the floor, push it back down, pull it up, a bunch of times.. maybe 20-25 times before releasing the bleed screw for the first time. There are many ways to bleed the clutch and I've only done it a few times myself, but there are threads full of different procedures, special tools, etc.
A great ending is all you'll see..
__________________________________________________ _____________
Might want to try this. Let us know if you succeed.
Bleeding the Clutch Circuit
The only sure way to bleed the clutch is as follows:
Make sure the rear portion of the master cylinder reservoir is full.
Dismount the slave cylinder, but leave the hose connected. Push the actuator rod all the way in. Let it out slowly. Repeat 3 times. Remount slave cylinder.
Good idea to orient the cylinder so that the hose connection is at the highest position, so the air can be flushed out.
BMW has a Special Tool to compress and release the rod.
Similar to Edjack
This is how I bled my new clutch hydraulics for my E39 manual swap based on an excellent tip from my indie tech
-worked first time with no drama.
-elevate car
-disconnect slave cylinder from trans
-use a cheap foot long, carpenter's squeeze clamp to depress the clutch slave piston
-attach a pressure bleeder to brake reservoir with fluid and 10-15 psi
-go down and open the clutch slave bleeder screw with a hose into a jar
-depress the clutch 2-3 times to make sure fluid is flowing through master attached to pedal
-stop bleeding when air bubbles stop in jar
-make sure there is no pressure (from pedal or pressure bleeder) when releasing clamp on slave
-reinstall slave cylinder in transmission.
↑↑↑ edjack's got it. I've been playing with BMWs since E3/Bavaria days and bleeding the clutch has always been weird, but the same. OP might have luck letting it sit overnight with a full reservoir or pumping the pedal by hand, including bringing it back up by hand, a hundred or two hundred times. That's worked for me after a roadside clutch M/C replacement on an E28. But above all else, don't open the bleeder screw on the slave. It doesn't work and it doesn't help.
There is at least one other completely different technique that works, but IMO it's harder and more complicated.
98 328is
02 525ita
80 528i
81 528ia
and decades of owning and driving BMWs
I always remove the slave, attached only by the hose. I use a clamp to compress the piston all the way in the bore, then pump/bleed the system.
With all the air out, remove the clamp and re-install the slave.
-Donny
Make sure the car is level, if you jack up only one side to crawl under the car and work the bleeder screw, it can make it impossible for the fluid to flow into the clutch side of the master cylinder reservoir, and it will never bleed. I learned this the hard way.
I've used the reverse bleed procedure twice with excellent results. A pump oil can like: https://www.harborfreight.com/20-oz-...-can-1113.html.
I've also done it by pushing the rod against the transmission body and hand pump the pedal a few hundred times. Reverse bleed is my go to way now.
2021 M340i (25k)
Sold!
Sold!
BMW CCA# 308494
Ive been snake bit with this car. Replaced the clutch master cylinder, slave cylinder and the steel/rubber line that connects them. Somewhere along the line, i saw the rubber hose was weeping.
I get everything reinstalled and hook up my pressure bleeder this morning. The slave cylinder is fully compressed. I pressured up to ~8psi and and opened the bleeder. Within 5-10 seconds i had a solid stream of fluid coming out. I close the bleed nipple, removed the pressure bleeder and took my clamp off the slave cylinder. When i went back in the car to press the clutch it, the pedal had a ton of resistance. I evidentially pressed the pedal a bit too hard and i heard the slave cylinder pop. I came apart and drained the clutch reservoir fluid.
Im at a total loss at this point. This shouldnt be that difficult. Am i missing anything big here?
2021 M340i (25k)
Sold!
Sold!
BMW CCA# 308494
unbolt the slave and let it hang by the hose with the bleeder facing up. Open the bleeder, it will gravity bleed. Do NOT push the pedal or the piston will be ejected from the slave, just let it drip.
2021 M340i (25k)
Sold!
Sold!
BMW CCA# 308494
Can the slave be reassembled or is it safe to say it's FUBAR at this point?
2021 M340i (25k)
Sold!
Sold!
BMW CCA# 308494
No reason it cannot be re-assembled. Be very careful not to damage the seal.
That must be what i did.
I got the slave cylinder back together and plan to rebleed this morning. The whole thing is held together by a simple press fit cap. I straightened it out and put it back together on my vice. A few taps with the right sized socket and Im back in business.
2021 M340i (25k)
Sold!
Sold!
BMW CCA# 308494
2021 M340i (25k)
Sold!
Sold!
BMW CCA# 308494
