Results 1 to 7 of 7
Thread: 1889 325i Sedan - Guibo to Manual Transmission
    Jun 2022
    Pierce County, WA
    1989 325i Sedan
    I need to preface my post with the fact that I'm reassembling an E30 after many years of being dis-assembled. So, I have little memory of how parts fit.
    I'm using new BMW OE bolts to secure the driveshaft guibo to the transmission. I'm assuming that the bolts are pressed into the guibo from the rear, leaving all bolt thread/nut protruding from the transmission side of the guibo. Is this correct?
    The problem I'm having is that one of the pressed-in bolts (round bolt head) will not grip the steel bushing in the guibo and therefore spins when I try to torque down the locknut.
    Any comments will be greatly appreciated.
    Nov 2009
    Des Moines, IA
    90 ix, 91 i & ic, 02 325
    Pictures here in a recent thread
    https://www.bimmerforums.com/forum/s...s-Acceleration
    bolt heads "pressed in from the rear" meaning from the rear tires towards the transmission - is correct.
    Make sure the guibo arrows are correct - and pointing to the flange.
    If I understand correctly - the steel bushing should not spin? unless I am missing something - that would suggest a bad guibo.
    Can you post a pic of what you mean?
    1974 Fiat 124SC
    1981 Porsche 911SC
    1990 BMW 325IX, 1991 BMW 325IC, & 1991 BMW 325I
    2002 BMW 325I
    2012 BMW X3
    Nov 2009
    Des Moines, IA
    Closer pic of guibo
    below is the pic of a damaged one - see the cracks - also the metal bushings should not spin.
    the pics are from an automatic - I dont think the manual is much different
    https://www.realoem.com/bmw/enUS/sho...diagId=26_0023
    1974 Fiat 124SC
    1981 Porsche 911SC
    2002 BMW 325I
    2012 BMW X3
    Regina, Sask, Canada
    82 320i 89 325i
    there are tiny arrows on the guibo itself. they point to the bolts and bolt direction. it's easy to install incorrect.
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    Quote Originally Posted by 82eye View Post
    More accurately, the arrows point at the flange for proper orientation. The bolt typically passes from the flange side and into the guibo, but it is not a rule.
    "Howdy, Folks!"
    Nov 2019
    Milwaukee, WI
    1989 325ix, 2003 4.4 x5
    I think you have the wrong bolts! I believe you should have 6 hex bolts with hex nuts. You need two wrenches to install. There's nothing to keep the bolt from spinning.
    I think the differential uses a captive bolt that has a round head. You may have bought the wrong bolts.
    Jun 2022
    Pierce County, WA
    1989 325i Sedan
    Hex Bolts and a new Guibo
    Quote Originally Posted by Mikealwa View Post
    The round head bolts I have were freshly purchased from the local BMW dealer. But they are not working out as I explained in my post.
    I'm replacing the guibo and I purchased some Hex head bolts from Tacoma Screw. Using two wrenches should eliminate the problem.
    Thanks so much for all responders pitching in. The photos were very helpful in understanding that the bolts can be installed from the rear side of the guibo.
    Cheers
  1. FOR SALE: 1990 BMW 325i Sedan 5 Speed Manual 77K MILES! $5,000
    By jamalq23 in forum 3 series & Z Series
    Last Post: 12-02-2017, 01:34 AM
  2. Replies: 1
    Last Post: 08-03-2014, 09:15 AM
  3. FS: 1989 325i Sedan 5 speed manual M50B25TU swap BAR legal.
    By MacLoGoS in forum 3 series & Z Series
    Last Post: 03-27-2014, 06:06 PM
  4. FS: 1989 325i Sedan 5 speed manual M50B25TU swap BAR legal.
    By MacLoGoS in forum E30 Parts Classifieds
    Last Post: 03-24-2014, 02:34 PM
  5. 2001 325i, 32K miles only, Manual Transmission for Sale, original owner
    By bonestock325i in forum BMW Cars For Sale / Wanted
    Last Post: 03-29-2005, 03:16 PM
