Results 1 to 3 of 3
Thread: Coolant level light
    Hanover,PA
    2004 325I
    Coolant level light
    The coolant level light is slways on on my 2004 330xi. I have replaced the sensor twice. All my mechanics say when they connect wires the light goes out. So it’s a sensor problem as my coolant level is fine. I’m thinking it could be a faulty connector?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved to E46 forum.
    Check the connector, maybe the pins in the connector retracted and have no contact when the connector is plugged onto the sensor, because your mechanics made a wire bridge and the light went out
    Mar 2016
    Portland, OR
    2002 325Ci Cabriolet
    The coolant level indicator inside the Expansion Tank is a magnet that is attached to the bobbing red plastic stick. If the magnet is no longer attached or has somehow managed to slide down the bobbing red plastic stick, your coolant light would always be on.
    https://www.bimmerfest.com/attachmen...ev-png.368618/
  1. coolant level light on
    By ronnie38 in forum 1983 - 1991 (E30)
    Last Post: 07-20-2008, 11:22 PM
  2. Check Coolant Level Light Came On
    By msimp227 in forum 1995 - 2001 (E38)
    Last Post: 09-26-2007, 10:26 PM
  3. Coolant level Light
    By syazoo in forum 1999 - 2006 (E46)
    Last Post: 09-05-2007, 10:37 AM
  4. 540 "check coolant level" light????
    By newbimmerguy in forum 1996 - 2003 (E39)
    Last Post: 05-10-2007, 03:07 PM
  5. Check Coolant Level Light, Help.
    By nvsage in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-18-2003, 01:20 PM
