Results 1 to 15 of 15
Thread: Running rough after motor mounts
    Jan 2016
    Springfield, MO USA
    1999 M3 coupe
    This is odd, I know. I swapped in new motor mounts on my '99 two nights ago. Very simple. Unbolt, raise the motor a little, put new ones in. The next morning, it seemed to be ok when I started it, but by the time I got to work something wasn't right. It stumbled and hesitated at idle, but smoothed out once I got going. On the way home, though, it steadily got worse. It bucks and stumbles regardless of RPM. It sounds like it has a serious engine miss, but isn't throwing any codes. I crawled all over it last night looking for something that had come undone, but didn't see anything. I fired it up this morning and it's almost undriveable. Any ideas on what might have happened?
    Marietta, GA
    95 M3, 87 535is
    Vacuum leak. Probably tore the intake boot/elbow when raising the engine.
    KC
    1995 M3 & 1998 M3 coupes
    Quote Originally Posted by jayjaya29 View Post
    I want to second this. Depending on the age of the intake boot, it could look ok, but when it flexed while raising the engine it could have cracked. Or in the case of my intake boot, it was darn near ready to crumble away. My idle was horrendous.
    When I took it off I noticed this.....
    Jan 2016
    Springfield, MO USA
    1999 M3 coupe
    No issues with the intake boot. In my experience, a vacuum leak will cause idle issues, but be less problematic as RPM climb (and throttle opens). In this case, it's regardless of RPM or throttle position. What it sounds like is a car with the timing waaay off. Like the timing has retarded so far that it barely runs. Is there something that could cause that?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Ground cable on the passenger side mount?
    Savannah, GA
    1987 325is/s52 swap
    When I went to solid mounts on my swap, the headers were hitting the front subframe ever so slightly. The above posters are probably correct, this is just something else to check.
    Actually reading your post, yeah check that ground cable.
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    It sounds like coils to me. I don't see any cause/effect, but this sounds like how mine behaved when one of the coils failed. So it sounds electrical to me - that ground strap might be the issue.
    Jan 2016
    Springfield, MO USA
    1999 M3 coupe
    Quote Originally Posted by blckstrm View Post
    Did you get a misfire code when yours did that? I pulled all the coils and plugs last night and didn't see anything obvious.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    - Hoses under the intake all plugged in?
    - TPS plugged in (cable and plug not damaged?)
    - pull each coil plug one at a time ... does the sound change for all of them?
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Jan 2016
    Springfield, MO USA
    1999 M3 coupe
    Good suggestions, here. I'll try all of them tonight. Thanks.
    Jul 2011
    Austin, TX
    Quote Originally Posted by ambric View Post
    Nope, no codes. And yeah, there's nothing to see. If someone is close you could borrow a set of known good coils and test it fairly easily.
    Savannah, GA
    1987 325is/s52 swap
    I thought of something else to check. If you were raising and lowering the engine maybe you induced an exhaust leak around the headers? That could cause the issues as your A/F ratio would be jacked up. It also would take a good amount of driving to throw a code.
    Jan 2016
    Springfield, MO USA
    1999 M3 coupe
    It looks like BLKSTRM and ScottH are the winners in this... I pulled the coils one at a time. Every one of them bogged the motor except number 3. I swapped the #3 and #2 coil and plug and the problem stayed with cylinder 3. At this point, I'm thinking it was just bad luck that it happened when I swapped motor mounts and I have a bad injector on cylinder 3. Any other thoughts?
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    if the problem stays, that does seem likely! a bit more messy to change injectors than coils ... but short of a wiring issue or really low compression, seems like injector is the logical conclusion.
    Jan 2016
    Springfield, MO USA
    1999 M3 coupe
    Quote Originally Posted by ScotcH View Post
    I thought the same thing. I checked and compression is 182-190 across all cylinders. I ordered an injector, since they're relatively cheap. We'll see...
  1. tii running rough after 20 mins
    By beezm6 in forum 2002
    Last Post: 06-12-2012, 03:05 AM
  2. runs rough after sitting
    By Flinxx in forum 1976 - 1989 (E24)
    Last Post: 06-13-2008, 03:11 PM
  3. Car running rough after clutch replacement
    By mischief3003 in forum 1983 - 1991 (E30)
    Last Post: 04-03-2008, 11:54 PM
  4. BMW 325i 1994 runs rough after warm up
    By Dean325i in forum 1991 - 1999 (E36)
    Last Post: 02-04-2008, 06:33 PM
  5. 328i runs rough after it Warms Up HELP
    By malibu73 in forum 1991 - 1999 (E36)
    Last Post: 08-17-2007, 07:39 AM
