Results 1 to 5 of 5
Thread: E36 inpa
    Sep 2022
    Poland
    E36 m52b20 1996
    E36 inpa
    Hello, sorry if there's another post about that, i tried to find something but I didn't found anything about mine problem.
    I have e36 m52b20 1996 with siemens ms41
    When i am trying to connect with inpa by using inpa compatible cable and 20pin - obd2 adapter I'm getting error IFH-0003. We tried inpa cable on other e36 and it works good. I had checked all 20pin cables to ECU plug and it seems that cables are ok. I have no idea what to do.
    The Netherlands
    DE-spec E36 328i/M3 cab
    There is a whole dedicated subforum regarding coding and diagnostics.
    Maybe this specific module needs ADS protocol, but I have an MS41 and it doesn't so I expect something else.
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    My similar problem was a bad cable. Different cable worked fine. ..... If it matters: I had a good cable for my 98M Roadster. I later bought a switched cable for my wife's 2006 330i (turns out I didn't need to). It was the switched cable that was no good.
    Sep 2022
    Poland
    E36 m52b20 1996
    I already tested this with 2 cables non of them worked with my car
    Sep 2022
    Poland
    E36 m52b20 1996
    I took my ECU out from e36 and connected to it wires, i can easily connect with it using inpa. That means mine engine harness is broken somewhere.
  1. E36 INPA ABS Codes
    By BillyDee36 in forum Diagnostic Software
    Last Post: 05-29-2020, 12:37 AM
  2. 95' E36 INPA can connect only to Airbag and EWS
    By barin in forum Diagnostic Software
    Last Post: 12-28-2018, 05:17 AM
  3. E36 inpa/DIS Connection
    By Dodolover in forum Diagnostic Software
    Last Post: 11-23-2015, 04:57 PM
  4. E36 INPA script errors
    By silverbullet21 in forum Diagnostic Software
    Last Post: 05-04-2012, 07:16 PM
  5. E36 INPA deciphering
    By KevinMullins in forum 1991 - 1999 (E36)
    Last Post: 09-06-2011, 01:58 PM
