The mirror will tilt down but it won't tilt back up. I've seen references to a passenger mirror control module, is that what is responsible for that operation? I couldn't find much information about the module.
I had this issue years ago. Battery nap took care of it. Here is the pinout on the module also.
A24 Passenger's door module
Plug connector overview
Pin assignments at plug connector X889
Number X-pin, colour Description X889 5-pin, black Plug connector Passenger's door module X1130 12-pin, black Plug connector Passenger's door module X1131 18-pin, natural Plug connector Passenger's door module
Pin assignments at plug connector X1130
Pin Type Description / Signal type Connection /
Measuring notes1 E Terminal 30 Fuse F8 2 M Control unit ground Ground connector 3 Not used 4 A Power window motor signal, close Passenger's window motor 5 A Power window motor signal, open Passenger's window motor
Pin assignments at plug connector X1131
Measuring notes1 A Actuating signal, outside mirror drive Outside mirror, passenger's side 2 A Actuating signal, outside mirror drive Outside mirror, passenger's side 3 A Actuating signal, mirror adjustment Outside mirror, passenger's side 4 A Actuating signal, vertical mirror adjustment Outside mirror, passenger's side 5 A Mirror heating Outside mirror, passenger's side 6 A Actuating signal, horizontal mirror adjustment Outside mirror, passenger's side 7 A Ground, mirror heating potentiometer Outside mirror, passenger's side 8 A Microswitch ground supply Outside mirror, passenger's side 9 E Mirror disengaged signal Outside mirror, passenger's side 10 E Mirror potentiometer, horizontal Outside mirror, passenger's side 11 E Mirror potentiometer, vertical Outside mirror, passenger's side 12 A Mirror potentiometer, positive Outside mirror, passenger's side
Measuring notes1 A Unlock motor signal Central locking (ZV) drive passenger's door 2 A Signal Memory switch Passenger's door Passenger memory switch 3 E Open window signal Passenger's door power window switch 4 Not used 5 A Signal Memory switch Passenger's door Passenger memory switch 6 A Signal, passenger's door contact Passenger's door contact 7 Not used 8 Not used 9 Not used 10 A Signal, lock motor Central locking (ZV) drive passenger's door 11 E/A P-bus signal line P-bus connector 12 E Close window signal Passenger's door power window switch 13 A Signal Memory switch Passenger's door Passenger memory switch 14 Not used 15 Not used 16 E Signal, motor position Central locking (ZV) drive passenger's door 17 E Signal, anti-jamming system Jamming protection switch, passenger's side 18 A Signal, memory LED Passenger memory switch
It's been acting that way since I started trying to resurrect this beast months ago, with many battery disconnections and no change in behavior. I had thought that maybe once I chased down all the diagnostic codes it may magically start working, but no dice. Anyway, I had found a module on ebay for like $15 and gave it a shot. Came today and I put it in, and now my mirror dips and returns. Yay me. Now to figure out the central lock switch...
Good to hear. My central lock and flasher switches were like many, full of crud from spilled soda and such over the years.
The GM connectors can get wet via clogged sunroof drains. It's not that common as the water usually just makes it's way under the seat where the fuse block and connectors are but it's worth unplugging and checking the pins for corrosion.
