Results 1 to 6 of 6
Thread: Doesn't recognize the key the first time
    Aug 2022
    OC, CA
    1995 BMW M3 Coupe
    Hey all,
    I am trying to figure out what's wrong with the ignition on my car. I have to turn the key twice. The first time, nothing happens. No lights, not cranking, absolutely nothing. If it turn it back to the 1st position and then it works normally and starts perfectly. If I turn it once, and pull the key out, the process resets and I need to turn it again twice. It's very strange and I cannot figure out why this is happening.
    I was thinking it was something to do with the EMS, but it "feels" like something mechanical when I turn the key the first time.
    I'm worried the car is going to leave me stranded one day.
    Here is a video of it happening:
    * https://photos.app.goo.gl/WLZb1Khkc54mJS2cA
    Thanks for the help!
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    It's your ignition tumbler, not the EWS.
    Look it up on realoem using your VIN.
    Aug 2022
    OC, CA
    1995 BMW M3 Coupe
    Thanks for the reply! I appreciate your expertise on this issue, because I'm stumped!
    Are you talking about the lock itself, #5 on this chart:
    https://www.realoem.com/bmw/enUS/sho...27#61328360925
    The key seems to be working correctly, no jiggling needed and the assembly as a whole isn't rotating (I saw this is a common problem where everything rotates). What is happening in the tumbler that is making it do this? Is it something that is repairable? or it must be replaced?
    Jan 2006
    Oakhurst, CA
    #5, yes.
    You could try removing yours and greasing it but I’m unsure what causes the barrel spin in the first place.
    Aug 2022
    OC, CA
    1995 BMW M3 Coupe
    Thanks! I'll pull it out and see what I can find. If it is barrel spin, I saw a video where they drilled a hole into the metal housing and used a screw to hold the barrel in place.
    Oct 2005
    Tracy, CA
    e46 325XI, e36 M3
    old but good info video on how to remove the igntion tumbler BMW Key Problem (Spinning Ignition) - MillerTimeBMW - DIY 5 - YouTube
  1. E90 N52 doesn't start first time
    By shahidm92 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-24-2016, 07:09 PM
  2. E39 530iA 2002 - EWS 3.3 Not Recognizing the key all the time
    By s73r01d in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-24-2016, 06:39 AM
  3. Replies: 1
    Last Post: 05-28-2016, 02:26 PM
  4. Replies: 0
    Last Post: 04-18-2011, 09:19 AM
  5. Car Keyed today, first time ever for me
    By Flawless in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-23-2003, 05:49 AM
