I was installing my 5 speed from underneath and the trans fell of my transmission jack. Under a foot fall but not a small fall either.
After the stumble, I'm having issues getting the input shaft (or whatever it is called) to move out of gear (shaft is all the way out)
I also drained the oil a bit working on the seals so maybe she just needs a top up.
What can I do to get her back to shifting? I used to be able to pull the shaft in and out with a screw driver but no longer.
Sent from my Pixel 5a using Tapatalk
Not too familiar with that. What is a detent?
Damn, spring plus ball bearing... This seems dangerous. Can I tap around that area to unbind anything or do I have to remove em?
I also ready I could beat the output shaft a bit?
I assume the selector rod or whatever shouldn't be touched.
