'04 e66 - Won't Start/Won't Crank - UPDATE
2004 BMW 745LI e66 - USA RHD - 110K miles
To review, the car sat idle for two months, now won't crank won't start.
I watched this YouTube video of diagnosing BMW starter issues using an Autel scan tool. ==> https://youtu.be/4U0MdHJhyos
He was enabled CAS ==> LIVE DATA ==> terminals ==> and while he pressed the start button he was able to read 12 volts and around 35 amps.
Using my Autel MD808 PRO scanner, I performed the same action however I only read 10v at terminal 50E and 9 amps at terminal 50L on a freshly charged 900 CCA AGM battery that is 2 years old. BTW, my charger does have AGM mode which is completely different than normal charging.
Next by LIVE DATA ==> INPUTS ==> I was able to confirm the brake light switch operates normally, which everyone knows is required to start the car.
I also found this BMW Training Module for the e65/e66 Car Access System (CAS) ==> https://ia801005.us.archive.org/11/i...s%20System.pdf
So now I have to wonder, am I dealing with a defective battery since I don't seem to be getting high current at terminal 50L.
Anyone else with experience of troubleshooting the CAS at this level?
TIA
'09 X6
'04 745Li
'97 Z3 1.9L
'94 740iL
'88 528e
'94 Jaguar XJS
'85 MB 380SL
