My 850i for sale, $14,900 located in the Milwaukee WI area. mostly original. I've owned it for 6 years, done much necessary maintenance including tune up,intake gaskets, cam cover gaskets, PCV system, Transmission fluid, filter, fuel lines, regulators, Aux heater valve/pump, batteries, fan and fan clutch. head light rebuild, front suspension ball joints, full rear suspension rebuild, rear brakes including parking brakes, rear wheel bearings, new bearings and seals in differential, rear brake lines fuel lines, filters. higher mileage at 156K, but with everything done, I'd drive it anywhere. the bad: headliner just started to drop in a small spot, sunroof doesn't work, some pixels out in the display. steering gear box is bit loose, haven't tried the tension screw yet. everything else is working as it should.will post pictures shortly. link to photos: https://www.facebook.com/marketplace...f&__tn__=!%3AD
Last edited by Joe850V12; 09-11-2022 at 05:38 PM. Reason: added face book link with photos
