Results 1 to 8 of 8
Thread: Hum at 30+mph speeds, goes away when banking right?
    Jan 2021
    Brooklyn
    1988 BMW 325i 4-Door
    Hello,
    My 1988 325i 4 door sedan with auto trans has been having a weird hum or buzz when since I bought it.
    The noise sounds similar to a tire rubbing on the body, though no tires are rubbing.
    The noise varies with road speed, not engine rpm. It starts at around 30mph and gets louder the faster you go.
    Today I went for a drive on the highway and noticed that when i swerved to the left to change lanes, the noise got louder. When I reached a highway junction, and the road had a long right turn to loop over to the other highway, the noise basically went away. Then when I was going straight, the noise came back. When I got off at my exit, the offramp was a long left turn, and the noise got much louder.
    So on right turns, the weight shifts to the left and noise goes away. On left turns, the weight shifts to the right and the noise gets louder.
    I'm thinking a bad bearing? Or could it be an axle? Anyone have any idea on how I could further diagnose this? Thanks!
    323i E30's Avatar
    323i E30 is offline ⅂!ʈө !ƨ l!ʞө ɐ ʇөlөbµouө
    Jan 2013
    Europe
    M52 E30 touring & E91
    I’d also think wheel bearings with these symptoms.
    Jack the car up, and spin your wheels by hand. See which one has play, or doesn’t turn as easily as the rest, or simply makes noise.
    I’d assume the bad one is on the right side of your car, as the noise gets louder with added pressure there.
    ^ true story
    D̶i̶b̶s̶ ̶o̶n̶ ̶t̶h̶e̶ ̶E̶2̶1̶
    Regina, Sask, Canada
    82 320i 89 325i
    second a wheel bearing
    Sep 2003
    whippany NJ
    1990 325is, 1990 325i
    Wheel Bearing in the front.
    Sep 2011
    London
    1990 335i tourer
    Sounds like either front right or rear right bearing, when you turn left the weight shifts to load the right hand bearings, so if they get louder then they are on the way out, turning right the weight shifts left unloading the bearings on the right hence they get quieter.
    Just need to determine if it is front or rear
    Sep 2003
    whippany NJ
    Usually the front will be much more sensitive to turning the steering wheel. If it's a rear bearing it will typically just change the pitch of the whine as your speed changes, if its in front you can get the whine to "turn" on and off as you turn the wheel.
    Jan 2021
    Brooklyn
    Well, finally took the time to jack up the front end. It is definitely the passenger side front wheel bearing. Got a new one sitting on the shelf waiting for me to put it in. Thanks, guys.
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    It's best practice to replace them in pairs, but it's not absolutely necessary to.
    "Howdy, Folks!"
  1. BMW jerks around 25-30 mph (when I am at a constant speed)
    By 3Squad in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-19-2016, 07:35 PM
  2. Front Wheel Vibration @ 65+MPH-Goes Away on Curves-What Is It?
    By Speedshift in forum 1991 - 1999 (E36)
    Last Post: 12-09-2010, 10:53 PM
  3. Gf goes away this weekend : what to do
    By Hugo in forum Off-Topic
    Last Post: 09-11-2003, 10:44 AM
  4. Steering wheel shake goes away after 5 min.
    By 98technovlt in forum 1992 - 1999 M3 (E36)
    Last Post: 09-03-2003, 04:18 PM
