Results 1 to 9 of 9
Thread: Oil In Coolant; Possible Causes?
    Feb 2010
    Nebo, NC
    '84 320i & 633, 87 325e,
    I have found what appears to be motor oil in the coolant in the recovery tank of my 1984 320i Eurospec (M20B20 engine); the blue coolant is now brown in color. Curiously, there is no evidence of coolant in the crankcase when I check the dipstick. Also, the car emits no steam from the tailpipe which suggests to me that coolant may not be getting into the combustion chambers.
    Is there anyplace else that I should look for a source before assuming that it is a blown head gasket or a cracked head or block? I really don't want to pull the head if doing so is not a slam-dunk, but I can't imagine where else oil is getting together with coolant. Suggestions . . ?
    Jeff
    1984 320i Baur TC2 5-Speed Opalgrün (Jeff's)
    1987 325e Sedan A/T Zinnoberrot (Dawn's)
    1984 633 CSi 5-speed Bronzit (Ours . . . if she says so)
    Nov 2009
    Des Moines, IA
    90 ix, 91 i & ic, 02 325
    You are on the right path - IMHO - head gasket . Might even explain your issues from the other posting - missing, stalling..
    tests I have used for head gasket diagnosis..
    Pressure test the cooling system
    Leak down test
    oil analysis
    Compression test - may or may not - although it will confirm a major issue
    1974 Fiat 124SC
    1981 Porsche 911SC
    1990 BMW 325IX, 1991 BMW 325IC, & 1991 BMW 325I
    2002 BMW 325I
    2012 BMW X3
    Feb 2010
    Nebo, NC
    Thanks, 95BMWIC, but these are two different cars. The car with the missing/stalling/etc./ problems is an '87 325e, the one with the oil in the coolant is an '84 320i Baur.
    Jeff
    Regina, Sask, Canada
    82 320i 89 325i
    your suspicions are bang on. it won't be more than a head gasket. check the head for warp as well, outside possibility it could need a reface.
    Feb 2010
    Nebo, NC
    Thanks, 82eye; I think I may let my BMW guru handle this one.
    Jeff
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    There's an oil passage between the block and head on the exhaust side between cyl 3 & 4. Look on the side of the block in that region and see if there's any oil seepage down the side of the block. It's fairly common to find. What ends up happening is that the seepage ends up making its way to the coolant passages. As the oil is under higher pressure than the coolant, transfer is in one direction. I do recommend using the original BMW head gasket set and avoiding the Victor Reinz kit. In my opinion, that VR kit is much more sensitive to surface prep and the BMW part is a superior part. Although I've not used them, I've not heard anything bad about the Elring kits.
    "Howdy, Folks!"
    Feb 2010
    Nebo, NC
    Thanks, Richard; you always give me good, usable info. I appreciate that. What is the best source for a BMW Genuine gasket for my Eurospec oddity?
    Jeff
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Be sure to verify this on realoem with the VIN. I'm assuming you're talking about the Baur. The top end gasket set which includes the head gasket is PN 11121730876. My current go to for original BMW parts is bmwpartsdeal.com where it's $288 (MSRP $374). The gasket all by its lonesome is PN 11121722728 and $126.
    "Howdy, Folks!"
    Feb 2010
    Nebo, NC
    Thanks, Richard!
    Jeff
  1. Oil in Coolant, but no Coolant in Oil...What's the cause?
    By E36Bimmer93 in forum 1991 - 1999 (E36)
    Last Post: 03-30-2016, 08:26 PM
  2. Burning coolant- possible causes?
    By Dannorth in forum 1991 - 1999 (E36)
    Last Post: 10-24-2011, 03:24 PM
  3. Loss of Oil Pressure, possible causes?
    By pctravel in forum 1992 - 1999 M3 (E36)
    Last Post: 02-16-2010, 12:09 PM
  4. Loss of Oil Pressure M3, possible causes?
    By pctravel in forum 1991 - 1999 (E36)
    Last Post: 02-06-2010, 10:01 PM
  5. oil in coolant - possibly ATF ?
    By Nacanowhere in forum 1991 - 1999 (E36)
    Last Post: 08-07-2007, 01:17 AM
