Results 1 to 7 of 7
Thread: 95' E36 M3 Euro price estimation
    Apr 2019
    estonia
    1995 BMW M3 Coupe (3.0)
    Question 95' E36 M3 Euro price estimation
    Hello everyone,
    For the past 6 years I was restoring a garage-find M3, that was left for 10 years. It has been a bit of a long run, as my ultimate goal was to not just the restoration, but also keeping it as original as possible.
    Currently, I am about to finish this project and I have started researching the market, looking for potential buyers and estimating the price. But the more I study the market, the more questions I have regarding what could be the price of the car. It is relatively volatile and I want to know what are the real price indicators, hence I am writing this post.
    A little bit about the car.
    01.1995 Euro E36 M3 Coup
    S50B30 engine 286 ps
    118k KM (73k miles)
    Manual
    Cosmic Black, 70-80% of paint is original
    Almost no rust
    Style 24 wheels
    Full black leather interior. Very good condition, leather is original. A good indicator of the mileage.
    A lot of service history is missing
    Work in progress:
    Vanos rebuild
    Full engine diagnostics
    Throttle body adjustment
    Work planned:
    A/C fix
    Minor interior/exterior restoration
    On board computer display fix
    Bottom clean up/restoration
    Brake system rebuild
    Expected to be finished within 3-4 months
    Work done:
    Chain replacement
    Engine timing
    Camshaft cleanup
    Oil pump fix
    Water pump, rollers, belts replacement.
    Exhaust system diagnostics, fix
    Ignition system diagnostics, fix
    Fuel system clean up
    Air leak fix (this took quite a while...)
    Countless gasket replacement (never gone below engine head, no necessity)
    Headlight restoration
    ICV cleanup
    Countless replacement of parts such as sensors, plastics, hoses, spark plugs, cables and so on..
    All parts replaced are OEM, either new or in perfect condition.
    Considering that everything that I am currently working on and everything that is planned is finished, what the price of the car could be? Trying to bring a bit of objectivity to this question.
    Thank you!
    Apr 2019
    estonia
    UP
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Good looking car. I asked the same question about my car here.
    Different countries, too many differences to really base the value of your car on the suggestions in that thread.
    Don't let it go for a low price!
    88M3 AW 43k miles Project FS
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    Fixing broken things doesn't add value - it just gets you back to the baseline.
    Wear items would "count" - but only if the date is somewhat recent relative to the item replaced. A new timing chain does not "count" - especially in a car with mileage a low as yours.
    Most of your work listed is something I'd expect is working properly on a car with your mileage.
    And you do NOT list the maintenance items that I WOULD expect / are commonly known: no suspension / bushings, no new radiator, etc.
    You're fixing things that shouldn't be broken and you're not refreshing things that do need to be refreshed.
    Find similar cars with similar mileage in your location (which might take some time to get a good sample), and when you're finished with the work you're planning that's about what yours should be worth.
    As it stands, it should be worth less than the average car with similar mileage.
    Having said that, it doesn't mean it's not worth anything. It's just worth less compared to similar cars without the problems. Once fixed, it should be worth about the average of the other cars you find with similar mileage.
    Feb 2019
    Memphis, TN
    1999 BMW 328is
    Even though the value of these, especially the M cars, is going up, don't expect that you can fix one up and actually make money on it. People fix these as drivers for the most part, not flipping them. The only way you can normally make anything at all is if you decide your time is worthless, and you just need to make a little more than the parts cost.
    But if you're having fun doing it, go for it. It's just not going to give you a monetary return.
    The Netherlands
    DE-spec E36 328i/M3 cab
    Quote Originally Posted by blckstrm View Post
    Quote of the year nomination right there.
    IG:
    USA
    BMW and Merican
    I just paid mid 20's for one, that was REALLY nice, then I did a bunch of deferred maintenance. To me , my car is worth 35-40K all day. It does have a brand new spectacular paint job though, all leather, no rust, no real flaws, just needed a bunch of maintenance to be done.
  1. 95 e36 m3 euro sport chip 3.5 maf 19lb injectors
    By starwind in forum Engines, Performance Parts & Software
    Last Post: 08-28-2012, 06:48 PM
  2. E36 M3 Euro Floating Front Rotors...Special Price!!!!
    By Midnight Oil in forum Brake Kits, Rotors & Pads
    Last Post: 06-30-2010, 05:18 PM
  3. '96 E36 M3 Euro ***Price Reduced***
    By Bimmer96 in forum BMW Cars For Sale / Wanted
    Last Post: 05-04-2007, 11:44 AM
  4. Wtb:oem Euro Clear Corners 95 E36 M3 Coupe. Asap.
    By eurotekm3 in forum BMW Parts Wanted
    Last Post: 09-12-2006, 12:21 AM
  5. '94-'95 E36 M3 Euro Airbox
    By JB///M3 in forum BMW Parts For Sale
    Last Post: 01-07-2004, 11:42 PM
