Results 1 to 6 of 6
Thread: 1991 750il radiator Hoses
    Apr 2022
    Georgia
    1991 750il v12
    I can't seem to find the size/diameter for the radiator Hoses online and I don't want to take it off yet since I use the car every day does anyone know what the inside diameter is?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    ETK only shows the size of the hose clamps, unfortunately I scrapped my old radiator hoses, but I have an old M70 radiator here and measured, outer dia. of the plastic hose connections of radiator ~ 41.5mm, inner dia. ~33.0mm
    Oct 2020
    Revolutionary City
    01 325cic, 90 750iL
    I have both radiator hoses waiting to install on my 750iL. I'll get you measurements later today!
    Edit:
    Hose end sizes are 39mm and 43mm. See photo for orientation. I'd say +/- 0.5mm because I measured with garbage calipers
    1990 750iL BronzitBeige Metallic
    2001 325cic OrientBlau
    NYC & Long Island & So FL
    '93 740il '84 633Csi
    Any recommendation for installing silicon hoses?
    Sent from my SM-G955U using Tapatalk
    Oct 2020
    Revolutionary City
    01 325cic, 90 750iL
    I tend to avoid silicone hoses because they're very water permeable relative to rubber and will eventually sweat coolant through the hose walls. On my other car, this happened in less than 4 years.
    Rubber lasts about 20 years and handles the heat just fine.
    It's a material best used for intake components
    Thanks for the info
  1. Radiator hose size for 1991 525?
    By FieroZ34 in forum 1988 - 1996 (E34)
    Last Post: 01-19-2013, 07:28 PM
  2. Help! Need ID of Upper Radiator Hose
    By Erik@EDGE in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-03-2003, 09:59 PM
  3. Anyone know ID of upper radiator hose?
    By Erik@EDGE in forum 1992 - 1999 M3 (E36)
    Last Post: 06-03-2003, 01:15 PM
  4. OEM radiator hoses..
    By alan2990 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-06-2003, 11:09 AM
  5. hi-mile radiator hoses?
    By ImageDynamicsM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-19-2002, 01:06 PM
