hello All,
i just picked up a 2007 M6, the car didn't come with a key, so i ordered one from the stealership.
but the car won't recognize the key, i'm getting the key with the diagonal slash error.
i pulled the following codes:
- A0B2 TERMINAL 30e/30L
- 5103 Supply voltage, gearbox
- 93AD Micro-power module no power supply
- A559 Instrumental cluster: power supply switched off
- A392 Emergency speaker, fault
so far i have replaced the battery and checked all the fuses in the glove compartment and trunk.
any help is appreciated.
I'm having the same issue. Did you register your new battery???
