I’ve only gotten this message like 4 times and it’s usually happened to me randomly. The car runs perfectly fine changes gears fine etc. I recently changed the crank shaft sensor idk if that’s related to the issue. I need help I’m not sure what to do.
First, report the message you're getting.
When did you last change the fluid and filter?
I recently bought the car August 8th and the previous owner kept it in good condition it was just missing a bit Of oil so I added a quart and that was about it.
One of the main causes of the TFS message is a low battery.
I'd vote to get your battery tested & rule that out.
<== Steptronic Sealbeach740
2000 740i sport: 74k Green/Tan chrome MPars, clear corners, quad brake lights, AIC hi-beams, Hoen fogs, 16x9 screen, MKIV, TFT LCD screen in back, license plate backup camera with "on demand" switch, iPod audio/video (CDC/iPod audio switching, iPod video on 16x9 screen), Basslink, gauge rings, ///M pedals, switched steptronic +/- shifting mode, E46 paddle shifter steering wheel, Dinan engine & tranny software upgrade, DDEs controlled via Euro fog light switch, painted calipers with "BMW" lettering, windows up/sunroof close via remote.
2003 540i sport: 81k, Sterling grey/grey, MKIV Nav, PDC & CWP - Added license plate backup camera with "on demand" switch, paddle shift steering wheel, windows up/sunroof close via remote, Akebono's, painted calipers with "BMW" lettering, quad brake lights, iPod audio via AUX mode/video via 16x9 screen, BMW TV tuner, ///M pedals & gauge rings.
Yes, first step : test the battery and alternator, and recharge the battery anyway.
I’m having the same thing intermittently on my 01 M62 but the car runs like a champion! Thanks for this insight guys! I’m putting the trickle charger on right now!
Also I am a little over 100K
Isn’t that the recommended time to change the transmission fluid and filter?
Thanks again!
Yes
Okay sounds good! Thanks for the help I really appreciate it
Hey my negative connector was very loose I disconnected and waited 15 mins then reconnected the error code hasn’t gone away. But idk if it takes a while for the car to notice
Disconnecting the battery won’t clear codes.
okay hmm then what can it be since my battery isn’t dead.
Your battery may be low, not necessarily dead... yet.
What is the voltage of the battery with engine off, then with engine running ?! Use a mulit-meter or the OBD menu on the dashboard to read it.
okay I’ll take it to my nearest auto shop later but also to add my car revs and accelerates very slowly
What Chedley said
Movin….what’s up with 2 posts on the same topic?
It’s better to just keep adding on to the original post, easier for others to follow and help you.
https://www.bimmerforums.com/forum/s...-failsafe-prog
Freakin guy thinks he’s moving so fast…. Apparently not.
lol my bad. Anyways i went to the nearest autozone they tested my battery and it was too low to even charge it was at 68%. It was also too late to charge it.
