Results 1 to 11 of 11
Thread: Several Symptoms; Could they Point to A Central Cause?
    Feb 2010
    Nebo, NC
    '84 320i & 633, 87 325e,
    Our 7-86-built 325e (unmodified condition) has several drivability issues. It is hard to start, lacks power and often hesitates, misses and stalls.
    Could all of these symptoms point to a central cause? Incidentally, the cold-start injector was replaced several months ago.
    Jeff
    1984 320i Baur TC2 5-Speed Opalgrün (Jeff's)
    1987 325e Sedan A/T Zinnoberrot (Dawn's)
    1984 633 CSi 5-speed Bronzit (Ours . . . if she says so)
    323i E30's Avatar
    323i E30 is offline ⅂!ʈө !ƨ l!ʞө ɐ ʇөlөbµouө
    Jan 2013
    Europe
    M52 E30 touring & E91
    What’s the condition of your cap & rotor? Maybe the contacts are worn to the point that it’s barely transferring spark.
    It’s an easy check.
    Fuel pressure may be worth checking too.
    ^ true story
    D̶i̶b̶s̶ ̶o̶n̶ ̶t̶h̶e̶ ̶E̶2̶1̶
    Sep 2003
    whippany NJ
    1990 325is, 1990 325i
    Check your spark plugs for condition as well as the distributor cap and rotor.
    Check your fuel pressure as your fuel pump may be failing
    Check the intake tract for cracks/leaks.
    Feb 2010
    Nebo, NC
    Thanks, guys; I'll check out the ignition system. Question: how many ohms resistance should the plug wires have?
    The Bosch fuel pump was new two years ago.
    Jeff
    Regina, Sask, Canada
    82 320i 89 325i
    check or replace all the intake and vacuum hose rubber.
    Sep 2014
    KS
    e24e30e36e39e90
    Step 1- smoke test, make sure the engine is sealed.
    Feb 2010
    Nebo, NC
    Thanks, 82eye.
    Jeff
    Thanks, sienayr.
    Jeff
    Nov 2009
    Des Moines, IA
    90 ix, 91 i & ic, 02 325
    Quote Originally Posted by BMWtyro View Post
    Jeff
    According to the Bentley Manual:
    Spark plug end connectors should have 5000 + - 1000 ohms resistance
    Distributor cap connectors including coil wire ends should have 1000 + - 200 ohms
    Wire itself - nearly 0 ohms
    Rotor should have 1000 + - 200 ohms
    Feb 2010
    Nebo, NC
    Thanks, 95BMWIC. When you say "spark plug end connectors" and "distributor cap connectors", are you referring to the end terminals crimped directly to the wires? If so, I'm not sure how one would test them individually. I can simply test both terminals simultaneously and I should get an aggregate resistance which should be somewhere around 1,500 ohms, yes?
    Jeff
    Nov 2009
    Des Moines, IA
    This is how I understand it (and have tested it)
    probe the spark plug wire from plug end connector to the other connector at the distributor 5000 + - 1000 ohms resistance
    probe the coil wire from the coil connector to the other connector at the distributor- 1000+- 200ohms
    1974 Fiat 124SC
    1981 Porsche 911SC
    1990 BMW 325IX, 1991 BMW 325IC, & 1991 BMW 325I
    2002 BMW 325I
    2012 BMW X3
    Feb 2010
    Nebo, NC
    Thanks!
    Jeff
  1. Several symptoms occur.
    By theonerainbow in forum 1995 - 2001 (E38)
    Last Post: 03-14-2011, 11:04 PM
  2. Central locking problems w/strange symptoms--Help!
    By jason325is in forum 1991 - 1999 (E36)
    Last Post: 08-20-2010, 08:27 PM
  3. central lift points on an E36
    By Asia in forum 1991 - 1999 (E36)
    Last Post: 01-22-2008, 02:27 AM
  4. several points of leaking...i dunno what to do.
    By Jo@EuroDyne in forum 1996 - 2003 (E39)
    Last Post: 11-20-2007, 07:38 PM
  5. Replies: 0
    Last Post: 09-28-2007, 05:52 PM
