Results 1 to 3 of 3
Thread: 2008 335i clicking behind glovebox
    Dec 2016
    Gonzales Louisiana usa
    2008 335i convertible,
    noticed this morning, my convertible when i turned it off the headlights and tail lights were still on, headlights set on auto. Turned the switch to manual and the headlights turned off but the tail lights were still on, cranked the car and turned it off and everything worked normal(everything off)i noticed a clicking behind the glove box when you start or turn it off im thinking its related.Thanks for a direction if any.
    Dec 2016
    probably should add battery was replaced about a year ago with a bmw direct replacement and coded in.
    Dec 2016
    i would like to follow up on this incase someone else has this problem. The clicking sound was coming from the fuse box behind the glove box, sounded and felt like a relay. Along with the clicking sound i noticed the emergency button on the dash would flicker. Had the footwell module checked out it was good. Sent the junction electrical box under the fuse box in and it had an issue changed it and everything is good. I also noticed over the past couple years if i let the car sit for a week or two it would have battery drain that seems to not be an issue as well now.
  1. Clicking noise behind glovebox...
    By 95750il in forum 1995 - 2001 (E38)
    Last Post: 10-20-2011, 11:48 AM
  2. 2008 335i
    By IR DOC in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 07-14-2007, 12:56 AM
  3. Replies: 1
    Last Post: 07-07-2007, 09:59 PM
  4. 2008 335i Sedan Question...
    By BMW32 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 06-03-2007, 03:43 PM
  5. Need Help With Loose Connectors Behind Glovebox
    By bigbris1 in forum 1991 - 1999 (E36)
    Last Post: 04-01-2005, 10:09 PM
