Results 1 to 2 of 2
Thread: Help with VEMS standalone
    Feb 2016
    Cary
    1998 BMW 323is
    Just finished building my m52b28 turbo car. And am having a hard time getting the car to idle evenly without going lean. Apparently my VE table is not correct according to my tuner and he thinks it is my injectors. Any opinions or advice would be much appreciated. Here is the build sheet for additional info…
    2.8L with studs and cut ring gasket
    VEMS Standalone
    Borg Warner S366SXE
    1650cc fuel injection connection injectors
    Walbro 450LPH pump set on 60psi(4 bar)
    On pump gas until I get a base tune and then switching to E85 or blend
    Stock compression
    I am trying to figure out how to post pictures of my VE table, lamda, and flow tables. Bare with me
    Chicago
    '99 M3
    Those are some HUGE injectors. Might want to chill those out a bit unless you're running 2000hp. Realistically how much power are you looking for?
    TEC-3R, T4 GT40, WISECO, EAGLE, SUPERTECH, O-RING'D "FRANKENSTEIN" STROKER.
  1. FS: M5x/S5x Garret Super 60/Log manifold and VEMs standalone
    By Revox71 in forum Engines, Performance Parts & Software
    Last Post: 08-06-2021, 11:13 PM
  2. WTB: Vems Standalone ECU
    By JRHemmen in forum BMW Parts Wanted
    Last Post: 12-13-2019, 03:05 PM
  3. VEMS standalone
    By TheJuggernaut in forum Forced & Chemical Induction Parts
    Last Post: 09-21-2018, 01:00 PM
  4. FS: VEMS standalone w/ Siemen Deka 60lb injectors + MORE!! $820 shipped
    By Tchao in forum Forced & Chemical Induction Parts
    Last Post: 04-28-2015, 05:59 AM
  5. I need HELP with Standalone choices
    By redforcedbmw in forum Forced Induction
    Last Post: 09-23-2005, 11:56 PM
