Results 1 to 11 of 11
Thread: 1988 bmw 325ci rear hub removal --help
    Dec 2020
    athens, al, USA
    1988 325 BMW convertible
    Hello, I have a 1988 BMW convertible. I'm trying to remove the rear hub to replace the bearings. I have removed the brakes, brake disc, E-brake, the hub nut, and i removed the aisle where it is connected to the Diff. Am I missing something? I have tried the different methods found on youtube. I tried using a bearing separator which allows using two lug nuts to tighten against it which should cause the hub to come off. I've tried using a large center punch to drive the aisle out of the hub. Nothing has worked. I don't even feel it has budged even a little. it almost feels like I'm missing a bolt or nut somewhere that is holding it back.. Appreciate any thoughts.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Once the larger 32mm, I think is the size, out you will need to drive the half shaft out. This can be accomplished by using a center punch and a 2lbs hammer, an air chisel, or just plain ole brute force of a sledge hammer if you don't plan on keeping either the hub or axle.
    Yes you can try a harmonic balance puller, for this will push out the half shaft too, what can help is tapping a bit on the hub as you tighten down the center bolt.
    Just remember to clean both splines and apply plenty of lube to get it back in.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Aug 2011
    Wake Forest
    2004 525i, 1985 325E
    Did you remove the locking ring, item 2 here?
    https://www.realoem.com/bmw/enUS/sho...diagId=33_0437
    2004 525i Sport, Manual - 1985 325E Coupe Manual
    dworthy's Avatar
    Nov 2010
    Quote Originally Posted by tomstin View Post
    That will be once the hub is out, the lad is still trying to get the half shaft removed.
    Darin
    Current:
    Past:
    M-Flight Member
    Nov 2019
    Milwaukee, WI
    1989 325ix, 2003 4.4 x5
    Are the half shafts splined into the bearing? I ask, because on my Nissan Altima it took 3 days, map gass penetrant spray and an 8 lbs sledge hammer before I saw movement. Some people have luck putting the axle nut back on and over tightening it the. Loosening it to maybe pull the axle a bit and brake the rusty bond. Again, not sure if this is your issue.
    Fyi, not that you will try this, but before I hit the axle this way I put the nut back on a few threads, then put a cheap socket on the nut and beat that with the sledge, ended up going full force, but it was that or toe it into a shop and I accepted the risks. It worked very slowly.
    Dec 2020
    athens, al, USA
    Thanks--i guess i need to use a little more elbow grease. I don't want to damage the hub or axle. I will keep trying---thanks for your help. I just don't understand what would be holding it back--maybe 34 years of resistance. Might ck on a harmonic balance puller.
    Dec 2020
    athens, al, USA
    Update--got the 1/2 shaft out. Now to get the hub off
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Quote Originally Posted by markbimmer View Post
    I used the lug bolts to get the hub out. Just screw the bolts into opposite holes in the hub, and slid some 1/4" steel plate between the end of the bolts and trailing arm bearing cup so that the bolts would push the hub out as they are tightened. Worked like a champ.
    Then you remove the retaining ring and pull out the bearings. If you have a bearing puller, that's awesome, but some of us have to make do with 2" PVC pipe, threaded rod, washers, and a large socket.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Dec 2020
    athens, al, USA
    thanks for the help an pic--i got the bearing off finally. just need to put everything back together
    dworthy's Avatar
    Nov 2010
    Glad to hear! As these cars get older, some parts will be very difficult to remove, so hate to say it, but get used to it.
    Darin
    Current:
    Past:
    M-Flight Member
    Dec 2020
    athens, al, USA
    I finally got everything back together on the hub and bearings. thanks for the help
  1. Rear seat removal help (E46)
    By BabyM in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-04-2010, 07:27 PM
  2. HELP with rear hub removal!!!
    By qwikslvr in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-27-2009, 08:52 AM
  3. Rear Seat Removal Help
    By billydakid2003 in forum 1991 - 1999 (E36)
    Last Post: 12-01-2007, 02:26 PM
  4. URGENT: rear spring removal help
    By laxwmatt in forum 1991 - 1999 (E36)
    Last Post: 04-20-2004, 01:17 PM
  5. URGENT: rear spring removal help
    By laxwmatt in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-17-2004, 11:39 AM
